Can I be running low on HPO with 225's? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-07-2010, 12:26 PM Thread Starter
Sponsor
jwarren's Avatar
Got 100% nozzles on my 225's and put a 66mm s300 on the truck
The truck is strong to redline but here is the thing when I lift off the throttle a little bit maybe 1/4 way and drop PW back to 2200 I can feel a increase in power. I will try to get a monitor hooked up tonight to check. Thought a stock 03 hpop was fine with 225's
BTW I still don't have a tune for the 225's with 100% nozzles just running Erics ext race file for stock injectors.
Trying to reach idp to get a new tune.
Got a pull sat eve and I got some trucks that need beat.
jwarren is offline
post #2 of 4 (permalink) Old 10-07-2010, 01:44 PM
<-- Got Air ?
Craig@MPD's Avatar
Re: Can I be running low on HPO with 225's?
If you put 100% nozzles on your injectors that had stock nozzles right ? Your injectors are probly around 265-275 range now and a 03 hpop cannot keep up with them
post #3 of 4 (permalink) Old 10-07-2010, 02:20 PM
I'm sure you'll have a decent drop in oil press. with those injectors, but you should still be in the low to mid 3k range. I got your message, but couldn't find your number. Give us a call, if you get the VM leave a message with your number and we'll call right back.
InnovativeDiesel is offline
post #4 of 4 (permalink) Old 10-07-2010, 02:49 PM Thread Starter
Sponsor
jwarren's Avatar
Thanx Eric. I got it all taken care of. You guys rock, IDP going in my sig right now.
jwarren is offline
