Wanna build a 6.0 puller and daily driver!?!? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 10-06-2010, 12:32 AM Thread Starter
6.0stroker250
Alright my plan is to buy a 6.0 motor and build it up slowly...I wana be able to drive it on the street and tow with it...but come pullin season i wanna be able to turn up my programmer and really watch peoples jaws drop when im gettin a full pull!!!
any suggestions on were to start
I know ill need head studs egr delete and all that good stuff i just dont know like what turbo to get and injectors..mostly just the internal stuff
2005 Stroker 6.0
6.0stroker250 is offline
post #2 of 25 (permalink) Old 10-06-2010, 12:34 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Re: Wanna build a 6.0 puller and daily driver!?!?
Start by finding an 06 or later motor.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #3 of 25 (permalink) Old 10-06-2010, 12:36 AM
Car Ramrod
06f250powerstroke's Avatar
190cc 64mm turbo gogo intake air dog II sct by IDP 4 link kit to stop the front end hopp and deep pockets im in the process of trying to build something the same as this
64mm non vvt
190cc
FASS 95GPH
CFM
ARP's
IDP FICM
MBRP-4"
KMC Rockstars
BFG-KM2
pure performance 4 link
BD diesel Diverter Valve
06f250powerstroke is offline
post #4 of 25 (permalink) Old 10-06-2010, 01:39 AM
Hood Rich
CTC DEEZUL's Avatar
Send a message via AIM to CTC DEEZUL
are there aftermarket rocker arms companies yet? What about high tenstion valve springs? You can bulletproof the heads, use stronger rod bolts, but then you still gotta worry about the valve train. These valves floats on high rpm and rocker arms shear...
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
CTC DEEZUL is offline
post #5 of 25 (permalink) Old 10-06-2010, 02:01 AM
motoxracer42's Avatar
elite has a roller rocker setup for around 4k. they also have a valvetrain that should help with floating valves without having to do it the expensive way lol. as for building a good puller that you can tow with is kinda hard. how heavy do you have to tow?
06 crew cab
06 reg cab
motoxracer42 is offline
post #6 of 25 (permalink) Old 10-06-2010, 02:06 AM
WWDD
Dzchey21's Avatar
couple trucks one fast one not
Dzchey21 is offline
post #7 of 25 (permalink) Old 10-06-2010, 02:19 AM
Hood Rich
CTC DEEZUL's Avatar
4k for rockers...... omfg
via Beans Toonz
DI SS Up-Pipe
GTP38R
post #8 of 25 (permalink) Old 10-06-2010, 02:25 AM
there is a ton of machine work involved. it does rev 6k though haha. they are on tadds race truck. there is actually a 6.0 motor out there with no cam in it and the company working on making one with no crank lol. i know it sounds crazy. the valve train runs completely off of spool valves.
06 crew cab
06 reg cab
post #9 of 25 (permalink) Old 10-06-2010, 02:26 AM
Car Ramrod
just with my set up now it has worked well at the pulls i have always been top 3 in the local class. I also went in the pro street class (2.6 class for y'all americans) and took 3rd. but they kicked me out cuz i didnt have a stack
64mm non vvt
190cc
FASS 95GPH
CFM
ARP's
IDP FICM
MBRP-4"
KMC Rockstars
BFG-KM2
post #10 of 25 (permalink) Old 10-06-2010, 02:27 AM
WWDD
Dzchey21's Avatar
all you really need is a turn up probably
Do you have suspension stops?
Dzchey21 is offline
