6.0 turbo rust - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 09-30-2010, 02:58 AM Thread Starter
Twan's Avatar
6.0 turbo rust
I have a 2006 6.0 that i had the stock turbo blow out on and ford put one in onder warrent and it was very laggy, took in in a few times they said it was just fine, then took it to a after market shop and they found the vains were all rusted. They tryed to clean it and it didn't help. Is there a better way to clean it to help it spoll better. they sanded it out.
Twan is offline
post #2 of 10 (permalink) Old 09-30-2010, 03:21 AM Thread Starter
Twan's Avatar
Re: 6.0 turbo rust
Loaded some pictures of the turbo on my profile.
Twan is offline
post #3 of 10 (permalink) Old 09-30-2010, 11:48 AM
mdfirefighter's Avatar
Re: 6.0 turbo rust
So, let me try to understand this, you are telling us that a ford dealership put in a non-rebuilt turbo while your truck is still under warranty?
2005 FX4 CC SB
Long block: Blackwater Engines
Turbo and injectors:
Thanks Dave!!!
Install: Impact Diesel & RescueF250
Thanks Kevin and Andy!!!
mdfirefighter is offline
post #4 of 10 (permalink) Old 09-30-2010, 11:51 AM
Sponsor
04stroker's Avatar
Re: 6.0 turbo rust
Take it back to ford.
HOLDERS DIESEL PERFORMANCE
Building and flowing 6.0 injectors in house
holdersdiesel.com
04stroker is offline
post #5 of 10 (permalink) Old 09-30-2010, 04:06 PM
Hate 'R Us
!!!PainTrain!!!'s Avatar
Re: 6.0 turbo rust
Strap it to a gas can/road flare fun bag and go visit the dealership!
!!!PainTrain!!! is offline
post #6 of 10 (permalink) Old 10-01-2010, 12:13 AM Thread Starter
Twan's Avatar
Re: 6.0 turbo rust
Its a ford rebuild, but the vains have rust, ford says its tested good every time, been in 5 times, they wont do anything for me, went to a different shop they said its seems laggy, but nothing they can do unless it test bad? Were can i find out how to clean the rust?
Twan is offline
post #7 of 10 (permalink) Old 10-01-2010, 12:23 AM
07strokerftw's Avatar
Re: 6.0 turbo rust
forget the rust, it's not worth trying to get rid of it, you need to find a dealer that will actually help you and get a different turbo
2007 F250 ccsb Lariat
33" Nitto Terra Grapplers on stocks, SCT x3 with custom extreme tunes from IDP, Autometer gauges, zoodad air mod, "2003" turbo, carriage works billet grill layover, HID 6000k, headstuds/egr delete, 6.4 banjo fuel bolt upgrade, 4" turbo back to 7" single stack
07strokerftw is offline
post #8 of 10 (permalink) Old 10-01-2010, 05:05 AM
SouthernSmoke
Re: 6.0 turbo rust
i would try droping the vanes in a bucket of drano crystals it worked for me but aint for sure about rust but it is the best thing i found
southernsmoke is offline
post #9 of 10 (permalink) Old 10-01-2010, 12:08 PM
Re: 6.0 turbo rust
I followed this when I did mine a while back.
Turbocharger Reconditioning
2005 FX4 CC SB
Thanks Dave!!!
post #10 of 10 (permalink) Old 10-04-2010, 06:08 AM
Re: 6.0 turbo rust
It helps to add centane boost to the fuel to help keep things clean(EGR & turbo) i use the Ford stuff so far it has worked for me use on every fill up.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS-Expandable Pyro
AutoMeter Fuel Pressure Gauge
Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC-coolant Filter
pulling 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
EGT,Boost,Trans
2 Stroker is offline
