Bypass transmission cooler - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 09-29-2010, 01:53 AM Thread Starter
I am thinking of getting a bypass filter for my transmission. Anyone have one and are they worth it?
I already have the bypass coolant system
strokedGator is offline
post #2 of 12 (permalink) Old 09-29-2010, 02:07 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Re: Bypass transmission cooler
It came with the truck. Look under the truck in front of the engine on the framerail on the passenger side.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #3 of 12 (permalink) Old 09-29-2010, 02:14 AM Thread Starter
Really? I did not know that. I will check in to it. Thanks
post #4 of 12 (permalink) Old 09-29-2010, 05:19 PM
professional slacker
alwil's Avatar
Thats going to be a cheap mod then...
alwil is offline
post #5 of 12 (permalink) Old 09-30-2010, 07:51 PM
there is a thermostat in the transmission. When the temps go over 170 it starts to open the fluid flow to the cooler.
Does the sterring system have a cooler? It looks like it but it is hard to see.
smokersteve is offline
post #6 of 12 (permalink) Old 09-30-2010, 07:52 PM
FNG
Dave's Avatar
Yes there is a PS cooler as well
Dave G
06 F250 Lariat 4x4 leveled on 35s
4 inch flowmaster exhaust
Bulletproof diesel egr delete.
Bulletproof diesel FICM
Performance Machine & Manufacturing Coolant Filter Kit
ECM and FICM tuned by Bill at PHP SCT tunes from Gearhead, Innovative and Wildman
Dave is offline
post #7 of 12 (permalink) Old 10-01-2010, 02:24 PM
The auto trans external filter is small cannister style. Follow the lines under the radiator. Like its stated, its located behind the radiator outside the passenger side frame rail.
The ps cooler is a small vane tube cooler that is located on the driver's side down low in the flowing air behind the front bumper. IIRC, its a single loop cooler.
Jagular7
2005 F350 CC C&C
No longer own
jagular7 is offline
post #8 of 12 (permalink) Old 10-01-2010, 03:13 PM
why does the trans lines go into the radiator? It looks like it is after the thermostat. If the trans lines are going into the eng radiator for warm up then shouldn't it be before the thermostat?
post #9 of 12 (permalink) Old 10-01-2010, 03:34 PM
alwil's Avatar
Every radiator I have ever seen has trans lines going to it.....I assume its for cooling not warming
alwil is offline
post #10 of 12 (permalink) Old 10-01-2010, 08:51 PM
Captain Negativity!
PSDPlayer's Avatar
Cools it down since the coolant can pull alot of heat out of it. Then it leaves there and goes through the auxillary cooler and back to the transmission.
Email:
