Oil Cooler???? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 09-28-2010, 03:30 PM Thread Starter
Oil Cooler????
I just bought a used 2004 excursion with 6.0L. Had diagnostics run by at Ford and they replaced the EGR valve. My next question is does this mean the Oil Cooler is bad and if so what to do next? Buy the kit from Bulletproof diesel? Little confused by posts after doing search. Seen more then one Oil Cooler fix and not sure if thats needed. On BPDiesel they say EGR goes bad caused by Oil cooler. Any suggestions going forward? Truck runs great just need it to go for quite a long time.
HardCorps88 is offline
post #2 of 6 (permalink) Old 09-28-2010, 04:31 PM
Re: Oil Cooler????
buy a coolant filter kit from dieselsite.com there around $130 it will stop all the debris from cloggong up the oil cooler which then takes out the egr cooler according to bulletproof
halerazor is offline
post #3 of 6 (permalink) Old 09-28-2010, 04:46 PM
Banning Smut
PTSUPERD's Avatar
Re: Oil Cooler????
This just showed up about 20 minutes ago....
PTSUPERD is offline
post #4 of 6 (permalink) Old 09-28-2010, 06:23 PM
Re: Oil Cooler????
Next up: Pics of clogged coolant filter!
That's a good kit; I've installed at least two of them.
Al
FTG-05 is offline
post #5 of 6 (permalink) Old 09-28-2010, 10:31 PM
It wasn't me
offroadinginaz's Avatar
Re: Oil Cooler????
Got 5 stock coolers?
Newman
A few Fords
Special Thanks to:
offroadinginaz is offline
post #6 of 6 (permalink) Old 10-04-2010, 12:38 PM
strokin24s's Avatar
Re: Oil Cooler????
i'm doing the same job. i'm going to do a egr delete and replace oil cooler. as installing exhaust and coolant filter kit.
strokin24s is offline
