Chromoly Pushrods... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 146 (permalink) Old 09-28-2010, 03:13 AM Thread Starter
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
So I was playing around in the solid model land. Needed some pushrods for a 6.4L motor to go along with some valve springs. The new springs have an extra 50lbs of seat pressure. And the motor had already seen some valve float as it had valve impressions in a few of the pistons.
So you start with a solid model...
The stock pushrod is made with a center tube .344 inches in diameter with a .060 wall thickness and has 3/8 ends welded to the end. The stock tube is rolled and has a seam down the side.
Stepped them up to .375 diameter with 3/8 ends. The centers are 4130 DOM Chromoly Steel with a .083 wall thickness. The ends are press fit and are precision ground and hardend. Here they are side by side. Stock length on these. I had cut the stock pushrod in half to measure the wall thickness.
Here is what the ends look like. These are good for over 700 lbs of open spring pressure. Which is more than 3 times the pressure of the stock spring.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #2 of 146 (permalink) Old 09-28-2010, 03:15 AM
Not Winning.
6.0 p-stroke's Avatar
Re: Chromoly Pushrods...
Are these gonna be for sale?
Cooper
04 6.0 CCSB fx4
08 6.4 CCSB 4x4
Special thanks to:
Logan Schneider at CenTex Diesel Performance
830-885-6500
Originally Posted by Powerstroked162 View Post
Lets be honest here, how many times have you been on the receiving end of a "Cleveland Steamer"?
6.0 p-stroke is offline
post #3 of 146 (permalink) Old 09-28-2010, 03:16 AM Thread Starter
Captain Negativity!
PSDPlayer's Avatar
Of course...
Email:
post #4 of 146 (permalink) Old 09-28-2010, 03:16 AM
Not Winning.
Price?
Cooper
04 6.0 CCSB fx4
08 6.4 CCSB 4x4
Special thanks to:
830-885-6500
post #5 of 146 (permalink) Old 09-28-2010, 03:22 AM
WWDD
Dzchey21's Avatar
hows that compare to elites pushrods do you know? What you going to do for springs?
Looks good doug
couple trucks one fast one not
Dzchey21 is offline
post #6 of 146 (permalink) Old 09-28-2010, 03:24 AM Thread Starter
Captain Negativity!
PSDPlayer's Avatar
Looking around 265 bucks for a set of 16.
Email:
post #7 of 146 (permalink) Old 09-28-2010, 03:25 AM
Not Winning.
Like Dustin said, what about springs?
Cooper
04 6.0 CCSB fx4
08 6.4 CCSB 4x4
Special thanks to:
830-885-6500
post #8 of 146 (permalink) Old 09-28-2010, 03:44 AM Thread Starter
Captain Negativity!
PSDPlayer's Avatar
Looks good doug
About 90 dollars cheaper.
Email:
post #9 of 146 (permalink) Old 09-28-2010, 03:46 AM
WWDD
Dzchey21's Avatar
i meant strenght wise and stuff.
Dzchey21 is offline
post #10 of 146 (permalink) Old 09-28-2010, 03:52 AM Thread Starter
Captain Negativity!
PSDPlayer's Avatar
Machined some shims and used some beehive springs...
They love to be run near coil bind. Unfortunately we need alot more lift before we would ever do that to these.
Email:
