help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 09-16-2010, 12:39 AM Thread Starter
Dirtyryder's Avatar
help
I put a new ficm on my truck from a shop it ran ok for a while now it is starting to do the same things cutting out when you first start it. i do have codes p006 p0103 p0266 p0401 p0404 p0405 i know some of these codes are from the intake and egr delete but i dont remember which ones any ways i took it back and he ran it on the computer when it was allready warm and every thing checked out good any help would be nice all so the truck tried to get hot on me last weekend when towing my inclosed trailer
Dirtyryder is offline
post #2 of 27 (permalink) Old 09-16-2010, 02:29 AM
Still learning
bad moose's Avatar
Re: help
Check harness connections. Also check for rubbed wires.
03 F250 King Ranch
SCT tuned by Eric @ Innovative, Exhaust, and Air Raid filter
EGR Deleted
Still to slow
bad moose is offline
post #3 of 27 (permalink) Old 09-17-2010, 10:31 PM
It wasn't me
offroadinginaz's Avatar
Re: help
You need to scan the truck when it is cold. You might have a bad injector or 2
Newman
A few Fords
Special Thanks to:
offroadinginaz is offline
post #4 of 27 (permalink) Old 10-02-2010, 06:11 PM Thread Starter
Dirtyryder's Avatar
Re: help
ok i scan it again and get back with ya i didnt know an injector would act up when its cold and check out fine when its warm
post #5 of 27 (permalink) Old 10-02-2010, 06:28 PM
Re: help
oil is thicker when its cold so the spool valves will stick. what oil are you running
halerazor is offline
post #6 of 27 (permalink) Old 10-02-2010, 06:31 PM Thread Starter
Dirtyryder's Avatar
Re: help
im running rotella 15- 40 or whatever it is
post #7 of 27 (permalink) Old 10-02-2010, 06:43 PM
Re: help
thats the worst oil for a 6.0 and has caused alot of injector problems. Use valvoline 5w-40 synthetic
post #8 of 27 (permalink) Old 10-02-2010, 07:30 PM
Hood Rich
CTC DEEZUL's Avatar
Send a message via AIM to CTC DEEZUL
Re: help
from a shop??? was it calibrated with the latest goodie bag full of stuff from Ford? You need an IDS program to do the FICM thing right... What was the voltage goin into FICM and what was coming out of it?
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
CTC DEEZUL is offline
post #9 of 27 (permalink) Old 10-03-2010, 02:28 AM Thread Starter
Dirtyryder's Avatar
Re: help
i think they calibrated it he said it was at 48 volts its kinda weird it ran great for about three days after he put the ficm in now its starting to do the same thing it was before the ficm took a dump all together
post #10 of 27 (permalink) Old 11-13-2010, 08:40 PM Thread Starter
Dirtyryder's Avatar
Re: help
well the shop tested my truck and i need#4 and #6 injectors are bad he said to replace all of them on driver side has anybody heard of diesel care performance they have injectors for 190
