Need more POWER!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 09-13-2010, 11:56 PM Thread Starter
Need more POWER!!
Wow am I glad I found this forum! I have some questions that I could really use some good input. I would like to get a sct programmer I know I need the EGR delete kit but I do not have the money for head studs. My question is there a tune that I can get that wont lift the heads. I'm just looking for a little edge nothing to crazy on average I pull 10,000 to 13,000 LB's. The truck is a regular cab with a 6 speed manual on 33's.
79puller is offline
post #2 of 15 (permalink) Old 09-14-2010, 12:05 AM
Proud Sponsor
Abrannan19's Avatar
Re: Need more POWER!!
SCT all the way, we can get you custom tunes that will be safer for stock headbolts.
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #3 of 15 (permalink) Old 09-14-2010, 02:14 AM Thread Starter
That would be great is there any thing else you would recommend doing I have not had very good luck with this truck? The first motor I had I only got 63k before it flatten some cam lobes then took out the main bearings and it was all stock. The new motor now has 50k on it. I'm a little scared to do any moods.
79puller is offline
post #4 of 15 (permalink) Old 09-14-2010, 02:43 AM
Reppin' the 6.4L
SickStroke6.0's Avatar
I think you need to upgrade the clutch, and and a coolant filter for sure.
Blake
Looking for a second 6.4L....
2008 F-250 CCSB King Ranch 6.4L
4" Rough Country Lift, Dual Steering Stabilizers, 20x10" XD Diesels, 35x12.50x20" Mickey Thompson MTZ's, Line-X, 15% Tint, MBRP 4" Cool Duals w/ 6" Tips, S&B Intake, Flo-Pro EGR Delete and Elbow, MBRP CAC Tube
SickStroke6.0 is offline
post #5 of 15 (permalink) Old 09-14-2010, 02:51 AM
SCT!! CUSTOM TUNES!!
79puller, start a signature so we know how you ride
smokersteve is offline
post #6 of 15 (permalink) Old 09-14-2010, 05:41 AM Thread Starter
A coolant filter? Sorry this is my first diesel
2004 Ford F-250 4X4 XLT
6 Speed
Airaid Filter
Stock!
1979 Ford F-350 4X4
"Pullin Truck"
79puller is offline
post #7 of 15 (permalink) Old 09-14-2010, 06:03 AM
Scab
Smokin6-0's Avatar
YEAH!!!! List all the fluids you put in your truck also.
ADAM
2004 ECSB
1997 CCLB
Originally Posted by PSDPlayer View Post
NASCAR ditched all the 7.3L response vehicles cause they couldn't get out to the accident scene fast enough. When lives matter, HP wins.
Smokin6-0 is offline
post #8 of 15 (permalink) Old 09-14-2010, 01:21 PM
Proud Sponsor
Abrannan19's Avatar
if you are running the higher HP tunes, you will need a clutch upgrade. You can get away with it for a while on like a tow tune or something of that nature, but when you get into the 100+ HP range it is more then the stock clutch can handle for extended periods of time.
If you are towing, its a really good idea to get some type of gauges with an exhaust gas temp readout, water and oil temp read out so you can see any possibly problems plus know when to let off the throttle.
As said a coolant filter is a good idea, it catches all the debris that floating around in your coolant system and prolongs EGR cooler and oil cooler life.
When running the higher HP tunes, its a good idea to do a turbo back exhaust and remove the cat, as its a pretty big restriction. You can do it on stock exhausts, but its not the greatest idea.
Adam Brannan
Email
post #9 of 15 (permalink) Old 09-14-2010, 01:22 PM
Proud Sponsor
Abrannan19's Avatar
LMAO, you should see his signature on other forums
Adam Brannan
Email
post #10 of 15 (permalink) Old 09-15-2010, 12:13 AM Thread Starter
Would it be better to get mechanical gauges or doesn't the SCT have a monitor? Also has anybody ran dual exhaust strait out the back? I would like to run a 4'' down pipe into 3'' duals would this work or is that too small?
6 Speed
Airaid Filter
Stock!
1979 Ford F-350 4X4
"Pullin Truck"
79puller is offline
