Trans Temp Gauge Bouncing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 09-13-2010, 11:09 PM Thread Starter
Basil Marceuaxdotcom
derrick's Avatar
I installed my glowshift gauges yesterday and they worked fine. Today I started the truck and after a few minutes, the trans temp gauge starts bouncing all over the place.....I checked the ground on the sender unit and it was fine.....and ideas?
2005 Lariat CCSB 4x4 6.0h crap what did we break
K&N FIPK, Straight Exhaust w/6" tip, SCT w/IDP tunes, High Idle Mod,Zoodad
Next: EGR Delete
derrick is offline
post #2 of 18 (permalink) Old 09-13-2010, 11:13 PM
Metal - It kicks your ass
Re: Trans Temp Gauge Bouncing
Check your ground again... Where do you have it grounded? Is it spliced into another ground or bolted to a metal piece?
I had the same problem and it was a bad connection. Sometimes it would bounce, sometimes it would work perfectly, and sometimes it wouldn't work at all. I went through a couple gauges and 1 sending unit before I chased down the ground.
Modded L99
dirtboy25 is offline
post #3 of 18 (permalink) Old 09-13-2010, 11:54 PM Thread Starter
derrick's Avatar
well it wasnt the ground....it was the sender wire.....the stupid heat shrink came off....just my luck....i had that sucker melted tight...or so i thought
i need to look more before i post.....just call me a post whore
Next: EGR Delete
derrick is offline
post #4 of 18 (permalink) Old 09-14-2010, 12:41 AM
NevrKnow's Avatar
At least it was a simple fix. Cheers!
2002 F-250 SD Lariat CC 4x4
7.3L automatic.
Underdash gauge pod with ISSPRO gauges.
Zoodad.
AIH delete.
DIY Tymar filter.
Sonnax Kit.
4" turbo back straight exhaust and 4-6" Silverline chrome tip.
20" wheels with 32x12.5 Toyo MT's
'08 aluminum rear diff cover.
SOLID AXLE front cover.
A/C Mod
NevrKnow is offline
post #5 of 18 (permalink) Old 09-14-2010, 01:12 AM
Sponsor w/out Blue name
powerstrokin15's Avatar
that's weird man. when I had them in they were fine? you like them?
HOLDERDOWN PERFORMANCE-Senior Salesman
'09 CC/SB FX4 6.4L
GearHead, IDP, KEM
powerstrokin15 is offline
post #6 of 18 (permalink) Old 09-14-2010, 01:46 AM Thread Starter
derrick's Avatar
I love them...it was nothing wrong with the gauges....it was my own crappy electrician work lol.....thanks so much man
Next: EGR Delete
derrick is offline
post #7 of 18 (permalink) Old 09-14-2010, 02:09 AM
Hells coming with me
maverik2711's Avatar
my trans gauge does the same thing. I was just about to post this problem lol. thanks for helping out.
Originally Posted by strokermax View Post
what do u mean troll no i dont hop out from under bridges as little kids walk by .
1997 Ford F250
Hypermax Stage 1's, custom tuned SCT chip, Dual 7 inch miter cut stacks, napa 6637, traction bars, suncoast built tranny Sold
2008 F250
H&S mini maxx
5" exhaust
S&B intake
dpf, egr delete
leveling kit
35" toyo's
20" moto metals
maverik2711 is offline
post #8 of 18 (permalink) Old 09-14-2010, 02:23 AM
cool man. np. if you need anything else hit me up
'09 CC/SB FX4 6.4L
GearHead, IDP, KEM
post #9 of 18 (permalink) Old 09-16-2010, 09:03 PM Thread Starter
derrick's Avatar
ok where are you guys grounding the sender? I have mine grounded to the skid plate under the transfer case and its still bouncing.....it will bounce from 0 to max until it warms up. then it will bounce from the correct temp to max and back and forth....its really starting to piss me off
Next: EGR Delete
derrick is offline
post #10 of 18 (permalink) Old 09-16-2010, 09:35 PM
BRING DA AMBALAMPS
stroke of luck's Avatar
mine did the same thing. I ended up replacing the sender and rewiring the entire thing. works like a charm now.
i would think glowshift would have some troubleshooting tips. you'll probably need to read some voltages across the sender and the gauge to make sure they're within spec and zero in on the problem. Glowshift should be able to tell you what the spec voltages are. if you're out of range, you can replace the bad part.
2005 CC FX4...compounds and everything else that goes with em.
stroke of luck is offline
