EOT and ECT sender location - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 09-13-2010, 06:55 PM Thread Starter
Ford Motor Co. Worker
I have a set of gauges on the way, and am trying to figure out where the best place (location) for the EOT and ECT sender should go. Anyone with experiance with this install please help.
I hear that Dodge is giving you a puppy with every truck you buy, so you'll never have to walk home alone again.
2007 F250 6.0L PSD Lariat 4X4 - Dieselsite Coolant bypass Filtation -Bilstein Shocks-Blue fuel pressure upgrade spring-Rough Country Duel Steering Stabilizer-Fumoto Oil Drain Valve-HFCM Water Separator Drain Plug Upgrade-ARP studded
headviking is offline
post #2 of 3 (permalink) Old 09-13-2010, 08:04 PM
Sponsor
dalpilot's Avatar
Re: EOT and ECT sender location
Oil Press and oil temp:
Page 13: Component Locations
For coolant:
Page 9: Component Locations
dalpilot is offline
post #3 of 3 (permalink) Old 09-13-2010, 11:09 PM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
I have my oil temp reading from a billet filter cap with the 1/8 NPT port at the top, and my coolant temp comes from the side of the block down on the passenger side. Another place for the coolant that I have seen some people do is drilling/tapping the little cover over the oil cooler where the EGR cooler connects to it.
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
