Methanol/Water Injection system - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 09-12-2010, 05:53 PM Thread Starter
Ford Motor Co. Worker
Can someone explain the Methanol/Water Injection system, how in works and why it is beneficial to the diesel engines if they are.
I hear that Dodge is giving you a puppy with every truck you buy, so you'll never have to walk home alone again.
2007 F250 6.0L PSD Lariat 4X4 - Dieselsite Coolant bypass Filtation -Bilstein Shocks-Blue fuel pressure upgrade spring-Rough Country Duel Steering Stabilizer-Fumoto Oil Drain Valve-HFCM Water Separator Drain Plug Upgrade-ARP studded
headviking is offline
post #2 of 4 (permalink) Old 09-13-2010, 01:00 AM Thread Starter
Re: Methanol/Water Injection system
Come on now one ever heard of this?
post #3 of 4 (permalink) Old 09-13-2010, 01:10 AM
Extended Power's Avatar
You could try Google...
Water/Meth injection
Snow Performance
Devil's Own
And what ever else pops up...
2003 F-350 KingRanch 4x4
Extended Power is offline
post #4 of 4 (permalink) Old 09-13-2010, 02:46 AM
Harry Callahan
The only reason you really need water injection is to keep down egt's on a modified engine. The water/meth for added power is a gimmick, sure it works some but the potential for damage is greater than the potential for gain.
Most "recreational" water injection systems are a joke, your money would do just as much good lining a garbage can, or better yet spend it on some real power adding hardware.
RDRCM#10
A select band of brothers- We stand together as one.
Giant VT-3, not stock
sniperonhigh is offline
