gauge question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 09-10-2010, 02:24 AM Thread Starter
tmars51's Avatar
gauge question
hey guys, ive got some simple questions for ya. I want to install two gauges and want some tips for the install.
first is Fuel. where is the best place to tap into the system for this? What PSI gauge is needed, and pictures help for me.
Second is battery volts. I know how to do this one for the most part, but is there any tips for our trucks that are the home of two batteries? or do you only read total system voltage with the alternator?
35 inch Hankooks with a level lift and F350 rear blocks, AFE stage 2 intake, Procomp dual steering stabilizer, HID headlights, Westin bull bar with Procomp lights, Dodge Cab Lights, Edge Evolution Programmer, coolant filter, Sinister EGR delete, smoked tail lights & 60 inch LED bar, straight piped, high idle mod, ZooDad mod
tmars51 is offline
post #2 of 10 (permalink) Old 09-10-2010, 02:35 AM
Diffrent Strokes
orrwhat's Avatar
Re: gauge question
you will need a billet aluminum fuel cap with a threaded hole in the cap so you can install a sensor. Dont forget that egt gauge! id recommend at least a 80 psi gauge.
orrwhat is offline
post #3 of 10 (permalink) Old 09-10-2010, 02:50 AM Thread Starter
tmars51's Avatar
Re: gauge question
for the fuel cap, i assume your talking for the filter on top of the engine correct? would you put a sending unit in there so you did not have fuel going into the cab?
as for EGT, i already have that.
tmars51 is offline
post #4 of 10 (permalink) Old 09-10-2010, 03:21 AM
06powerstroke's Avatar
Re: gauge question
Yes, the billet cap is for that filter. If you use an electric fuel pressure gauge then no fuel will run to the cab.
2006 F250 CC LB FX4 Lariat
ARP studs, SCT X3 IDP & Gearhead tuned, S&B CAI, straight pipe, FASS 150/180, FCDP solid uppipe, Dieselsite coolant filter
2.5" BTS leveling kit, 35" Xtreme A/T's on XD Hoss 18's, N-Fab prerunner bar w/ 3 9" Hellas
Pioneer double din, JL components, 3 10" Pioneer subs
06powerstroke is offline
post #5 of 10 (permalink) Old 09-10-2010, 03:38 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: gauge question
0-100 psi fuel pressure gauge, electric, Isspro EV2 is what I would recomend...
Volts, no need to do anything further then tap a keyed on Hot power anywhere in the cab...
Joe
CSIPSD is offline
post #6 of 10 (permalink) Old 09-10-2010, 10:42 AM
Re: gauge question
there is a port on the fuel bowl you can use as well..... thats where mine is.......
03 F-250 207000 miles, Mad Turbo Werks Stage 1 Turbo, RCD155 injectors 100% Nozzles, 150/180 FASS, FCDP EGR delete, ARP Headstuds, OEM head gaskets, Diesel Site coolant filter kit, SCT Tunes, Hellmans Sump, 4inch Magnaflow Exhaust, 6.4 banjo bolts, AR-9100 Oil Treatment, 58v FICM
F-250-Owner is offline
post #7 of 10 (permalink) Old 09-10-2010, 11:13 AM
Proud Sponsor
Abrannan19's Avatar
Re: gauge question
as CSI said, you want a 0-100 fuel pressure electric, I prefer autometer's.
Also the the keyed hot power wire is where my voltmeter is at.
The fuel pressure can be taken from the top of the secondary fuel bowl under the hood with a billet filter cap that's pre tapped for the sender, or you could go in the pressure test port fitting in the front of the secondary fuel bowl.
here is how mine was installed
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #8 of 10 (permalink) Old 09-10-2010, 01:59 PM Thread Starter
tmars51's Avatar
Re: gauge question
those pictures show exactly how i want to do it. where did you get all your stuff? did it come in a kit, or did you piece it together your self?
tmars51 is offline
post #9 of 10 (permalink) Old 09-10-2010, 02:00 PM
Proud Sponsor
Abrannan19's Avatar
Re: gauge question
I am a vendor, I can get you whatever you want.
Adam Brannan
Email
post #10 of 10 (permalink) Old 09-14-2010, 11:52 PM
99whitetanpsd's Avatar
Send a message via AIM to 99whitetanpsd Send a message via Yahoo to 99whitetanpsd
Re: gauge question
i know this is a 6.0L thread but i was looking to kinda do the same for my 7.3L. i want to install a fuel psi gauge. i already have the egt,boost, and pyrometer.
E99 f250 4x4 CC SB (sold)
7.3L powerstroke
292hp 658tq
[email protected] 1/8 mile
06 ram 2500 4x4 qc sb
5.9L 24V cummins
Originally Posted by Deereman4020 View Post
Fuk D-maxes I'll get a cummins before a D-max.
99whitetanpsd is offline
