truck from hell - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 40 (permalink) Old 09-09-2010, 02:23 AM Thread Starter
<-- Got Air ?
Craig@MPD's Avatar
truck from hell
i have a friends truck that weve been trying to get running for 6 months we have changed the following parts.....its a 2005 f250 harley truck with 10k
2 ficms
2 pcms
2 sets of injectors
both oil rails
both standpipes
injector harness
engine harness
cam sensor
crank sensor
icp
ipr
new hpop
ficm relay
glow relay
interior fuse panel
ignition switch
truck has 60 psi of fuel pressure 1200 psi of oil pressure good compression in all cylinders
the truck will start run for 2 seconds than shut off and repeat til you stop trying ....will fire and run on either
the truck had a auto start and we took it out and taped all the wires up
were lost and dont know what to do anymore
post #2 of 40 (permalink) Old 09-09-2010, 02:29 AM
bluedge8's Avatar
Re: truck from hell
I really don't have a clue here, but I would verify the motor is sound, then change the entire wiring harness with known good electronics. Drastic I know but it sounds like your there
1997 f250 4x4 sclb, auto, 3.55's, 191k, diy intake w 6637, ccv mod, pyro, boost, trans gauges, 3" dp to 4" single exh. super chips for now. scangauge
Originally Posted by jdc753 View Post
Besides there is absolutely no way to idiot proof something, since they are always coming out with better idiots by the day
bluedge8 is offline
post #3 of 40 (permalink) Old 09-09-2010, 02:31 AM Thread Starter
<-- Got Air ?
Craig@MPD's Avatar
Re: truck from hell
has a harness and electronics off my race truck that run
post #4 of 40 (permalink) Old 09-09-2010, 02:31 AM
Re: truck from hell
2 ficms
2 pcms
2 sets of injectors
both oil rails
both standpipes
injector harness
engine harness
cam sensor
crank sensor
icp
ipr
new hpop
ficm relay
glow relay
interior fuse panel
ignition switch
You have theft system problems related to the remote starter.
For Sale: 2000 F350, black cc sb 4x4
Jngreen is offline
post #5 of 40 (permalink) Old 09-09-2010, 02:32 AM
it's an 02 05 08
turbodiesel_02's Avatar
Re: truck from hell
definetly sounds like an electrical issue to me if it has fuel pressure and oil pressure,i had a 6.0 that would start and cut off after a second or 2 turned out to be a fuse that wasnt making good contact maybe try replacing the fuses perhaps
2002 ext. cab lwb 4x4 7.3
05 front 08 rear conversion
4in lift,forged rod motor,tunes by tsd,bts trans,6.0 transcooler,6 autometers to watch,studs,springs,push rods,238cc hybrids,itp reg return,stealth hpop,tsd custom fuel system and sump,an so on
6.0's pay the bills and 6.4's soon..
turbodiesel_02 is offline
post #6 of 40 (permalink) Old 09-09-2010, 02:35 AM Thread Starter
<-- Got Air ?
Craig@MPD's Avatar
Re: truck from hell
can you be more clear please
post #7 of 40 (permalink) Old 09-09-2010, 02:36 AM Thread Starter
<-- Got Air ?
Craig@MPD's Avatar
Re: truck from hell
replaced and tested every fuse
post #8 of 40 (permalink) Old 09-09-2010, 02:41 AM
Sponsor
04stroker's Avatar
Re: truck from hell
Same thing happened to me on my 6.0 if you have the equipment check and make sure your crank sensor is synchronizing and the motor is timed. Mine wasn't syncronizing turned out a tooth broke off the "tone ring" (that's what I call it) on the front of the crankshaft motor wasn't timing itself correctly. Would start hard run for 2 seconds then shut down.
HOLDERS DIESEL PERFORMANCE
Building and flowing 6.0 injectors in house
holdersdiesel.com
04stroker is offline
post #9 of 40 (permalink) Old 09-09-2010, 02:43 AM Thread Starter
<-- Got Air ?
Craig@MPD's Avatar
Re: truck from hell
Thats what we were thinking it might be hoping it isnt though
post #10 of 40 (permalink) Old 09-09-2010, 02:44 AM
Re: truck from hell
Sorry I can't because I'm not 100 percent certain that it is your problem.
My car, however, would do the exact same when I wired in my remote start.
I bypassed the theft system and all is good now.
I would think that you would see a theft light flashing at you or give you some kind of indicator. Does it throw any codes?
You might double and triple check all of your connections from the remote starter.
Jngreen is offline
