Oil Temp Gauge question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 09-09-2010, 01:06 AM Thread Starter
Basil Marceuaxdotcom
derrick's Avatar
I just got some glowshift gauges for my truck and I was wondering what to do with the oil temp gauge. I don't want to replace the factory unit because I want both gauges to work....I know with the new one, I'll never look at the factory one but I cant stand gauges that dont work. What is everyone else doing?
2005 Lariat CCSB 4x4 6.0h crap what did we break
K&N FIPK, Straight Exhaust w/6" tip, SCT w/IDP tunes, High Idle Mod,Zoodad
Next: EGR Delete
derrick is offline
post #2 of 15 (permalink) Old 09-09-2010, 01:10 AM
Proud Sponsor
Abrannan19's Avatar
Re: Oil Temp Gauge question
easiest, get a billet oil filter cap and put the sender there.
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #3 of 15 (permalink) Old 09-09-2010, 01:16 AM Thread Starter
derrick's Avatar
Ah crap I think we went over that not long ago.....Boy my memory sucks
Next: EGR Delete
derrick is offline
post #4 of 15 (permalink) Old 09-09-2010, 03:00 AM Thread Starter
derrick's Avatar
well i found one for $110....but it says for oil psi.....will it still work for oil temp?
Still kinda high....I'd honestly rather have the fuel psi and billet cap
Next: EGR Delete
derrick is offline
post #5 of 15 (permalink) Old 09-09-2010, 03:07 AM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
if its a billet cap for the oil filter then it should work for both low pressure PSI as well as temp, just depends on what sensor you put into the mount.
I have the billet cap and use it for oil temp.
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #6 of 15 (permalink) Old 09-09-2010, 03:09 AM Thread Starter
derrick's Avatar
Where did you get yours? Is $110 about right?
Next: EGR Delete
derrick is offline
post #7 of 15 (permalink) Old 09-09-2010, 03:15 AM
06powerstroke's Avatar
I got mine from Abrannan19 and I think it was cheaper than 110, but I'm not positive...
2006 F250 CC LB FX4 Lariat
ARP studs, SCT X3 IDP & Gearhead tuned, S&B CAI, straight pipe, FASS 150/180, FCDP solid uppipe, Dieselsite coolant filter
2.5" BTS leveling kit, 35" Xtreme A/T's on XD Hoss 18's, N-Fab prerunner bar w/ 3 9" Hellas
Pioneer double din, JL components, 3 10" Pioneer subs
06powerstroke is offline
post #8 of 15 (permalink) Old 09-09-2010, 03:39 AM
That Guy
Sniper32's Avatar
Im about to get both fuel and oil billet caps for 120 shipped so if that 110 is for oil only......your over paying
If You Aint Infantry You Aint Chit!
04 250 cc/sb - ARP, Toyo, Procomp, Sinister, Innovative, PHP, Edge, Isspro, etc
Sniper32 is offline
post #9 of 15 (permalink) Old 09-09-2010, 04:26 AM
Sniper
If you are going to run a fuel pressure gauge from the fuel billet cap then you are getting your pressure from the wrong place, you have to get it from the test port here Page 30: Fuel Supply System from your post it just sounds that way.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS-Expandable Pyro
AutoMeter Fuel Pressure Gauge
Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC-coolant Filter
pulling 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
EGT,Boost,Trans
2 Stroker is offline
post #10 of 15 (permalink) Old 09-09-2010, 04:35 AM
Originally Posted by 2 Stroker View Post
Sniper
2 stroker
And why is the cap the wrong spot? I'm pulling my fp from my billet cap, reads 50psi...
