6.0 upgrade stages and what is needed - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 09-08-2010, 03:21 AM Thread Starter
I have owned my 04 6.0 excursion for about a month now and was looking to do a few things for reliability and power. I have read alot on the forums and heard conflicting stories about what is needed and when. can you guys elaborate on what is needed for each hp gain or step?
I have an Edge platinum and am getting ready to do the oil cooler, EGR delete and possibly head studs if they are needed. I have deleted the cat but have not done a full exhaust and intake yet due to what I have read on the forums about when they are needed (saw something that said stock intake will support 500hp) I have also been told that I will need a turbo upgrade and upgraded injectors to make 500hp.
Bottom line. I just want a reliable rig that makes good power. What do I need to accomplish this with an 04 6.0.
thanks for any and all info.
supraman95 is offline
post #2 of 12 (permalink) Old 09-08-2010, 03:58 AM
It wasn't me
offroadinginaz's Avatar
Re: 6.0 upgrade stages and what is needed
start with studs and gauges
Newman
A few Fords
Special Thanks to:
offroadinginaz is offline
post #3 of 12 (permalink) Old 09-08-2010, 03:58 AM
Stroken it 7.3,6.0,6.4
weekendwarriorfsw32's Avatar
08 F 450 King Ranch 6.4
Elite Race trans, Spartanized, ARP, Icon 4.5 on 35's, RDP boots, HID'S, OUO ladder bars, 3" I/C pipe
04 X 6.0
08 tow mirrors, ARP studs, RDP boots.
01 X 7.3, Dp, Cass 238/80 Hybrids, Terminator Dual pumps, TNBB holding on for dear life @40+psi, TE thermostat, ARP studs, Fluidampner, RDP 6637, RDP boots
weekendwarriorfsw32 is offline
post #4 of 12 (permalink) Old 09-08-2010, 10:36 AM
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
Full exhaust
SCT
Coolant filtration
Studs
EGR Delete
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
post #5 of 12 (permalink) Old 09-08-2010, 12:12 PM
Lead-Don't follow.
06TWO50Diesel's Avatar
another vote for the above:
Turbo back exhaust
SCT tuner with IDPs street tune
Full EGR delete
ARP studs to hold it all together
You'll have a fun truck, push a bit more than 400 at the wheels and your 6.0 will be reliable for many miles.
-06 F250 6.0L-SOLD
We all die. The goal isn't to live forever, the goal is to create something that will.
---2011 F250 6.7 CCSB---
IDP Tuning+Torq2 | AFE | Recon | AMP steps | RBP wheels | Nitto
06TWO50Diesel is offline
post #6 of 12 (permalink) Old 09-08-2010, 12:29 PM Thread Starter
Thanks for the responses.
So if I everything that you guys recommend
Turbo back exhaust
SCT tuner
Full EGR delete
ARP studs
This should make around 400hp. How much torque is that?
It currently has an Edge platinum on it and I tweaked it a bit to be safe on the trans. Should I keep it or change it out?
post #7 of 12 (permalink) Old 09-08-2010, 12:35 PM
Proud Sponsor
Abrannan19's Avatar
It would be to your benefit to ditch the Edge and get a SCT.
The list is good and typically with a diesel, you have double the HP number in TQ, so at 400hp you should be around 800 lb ft or close.
Let me know if I can get you some prices.
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #8 of 12 (permalink) Old 09-08-2010, 02:10 PM Thread Starter
If I want to make more than 400 what are the next items I will need?
What is the power limits of the Torqshift trans?
post #9 of 12 (permalink) Old 09-08-2010, 02:41 PM
my mods in my signature should be around 450-500 or so I am told...... Adam got me most of my stuff....
03 F-250 207000 miles, Mad Turbo Werks Stage 1 Turbo, RCD155 injectors 100% Nozzles, 150/180 FASS, FCDP EGR delete, ARP Headstuds, OEM head gaskets, Diesel Site coolant filter kit, SCT Tunes, Hellmans Sump, 4inch Magnaflow Exhaust, 6.4 banjo bolts, AR-9100 Oil Treatment, 58v FICM
F-250-Owner is offline
post #10 of 12 (permalink) Old 09-08-2010, 03:14 PM
Sponsor
dalpilot's Avatar
When you start looking above your normal bolt on parts, it starts to get expensive. If your gonna do injectors, your gonna need a fuel system. Then your gonna probably start looking at high EGT's so an intercooler is gonna come into play, or swapping to a bigger turbo. Your stock tranny with the edge is doomed, but get an SCT and some good tunes and your good to go IF the tranny is in descent shape to start with.
See here for the EGR delete and save a few bucks.
EGR delete.....CHEAP - Powerstroke Nation
dalpilot is offline
