what are safe egts while towing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 51 (permalink) Old 09-06-2010, 12:15 AM Thread Starter
drservo's Avatar
My buddy has a 07 with innovative tunes and is wondering what are safe egts while towing. He has seen up to 1600 while towing up a 8% grade this weekend.
08 F250 CC, 4x4, Blue/Pueblo Gold, 3.73, S & B CAI, 5" Magnaflo downpipe back, Spartan TCM 275 & 310, KEM 345 (SCT - Sold) Mickey Thompson 35 12.50 20 Baja ATZ.
drservo is offline
post #2 of 51 (permalink) Old 09-06-2010, 12:30 AM
Re: what are safe egts while towing
1600* is very high. Try not to go past 1300 stained. You can hit 1600 in very short amount of time for the longevity of your truck
smokersteve is offline
post #3 of 51 (permalink) Old 09-06-2010, 12:31 AM
<-MONEY PITT!!
ifitssmokinitsstrokin's Avatar
What tune is he running? On Erics tow tune on my old 6.0 I never Had temps creep that high towing 7500lbs,maybe your buddy is towing some insane weight?
2010 CCSB Afe Intake and dual exhaust
2006 CCLB F-250 Studs,Squeez,EGR delete,RR to AirDog II and a Airraid Intake & Sct Hot tunes *SOLD*
1963 Chevy Nova II 88mm turbo 408 LSX backhalved and tubbed 9.22 @ 145 @ 5000ft BUILT NOT BOUGHT!
02 Cummins ECSB 5 spd,250s,edge comp 64 over a s475.. Work Truck
ifitssmokinitsstrokin is offline
post #4 of 51 (permalink) Old 09-06-2010, 01:30 AM
peterbilt'in
Rob02F350's Avatar
1600!
hope to hell he didnt hold it there for more then a split second.
mines not a 6.0, but ill tow all day at around 800-1000 swapping between 60T and 120 race depending on grade and needs.
2002 F350 extended cab XLT, 4x4 auto,194K mi @ 10/25/13, ELF7405, DP F5, ultra light gauges, all kinds of "improvements" Yukon Grizzly locker 6K helper springs, x code fronts. 2 Y2K jetta Tdi. RC2 tuned
Rob02F350 is offline
post #5 of 51 (permalink) Old 09-06-2010, 05:41 AM
1250 max sustainable temp. Never seen 1300 towing 10k for more then short bursts
TT
Zoodad mod, high idle mod, blue winshield washer fluid, cat delete mod, tinted windows
jonnysteals is offline
post #6 of 51 (permalink) Old 09-06-2010, 01:58 PM Thread Starter
drservo's Avatar
He's pulling 10k with Ericsson tow tune. If he runs stock he sees up to 1400 deg.
drservo is offline
post #7 of 51 (permalink) Old 09-06-2010, 02:45 PM
Proud Sponsor
Abrannan19's Avatar
he needs to use common sense and know when to let off when towing, I would highly suggest keeping EGT's under 1250* while towing.
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #8 of 51 (permalink) Old 09-06-2010, 03:43 PM
Ford Motor Co. Worker
Where did he install the sensor. Pre-turbo or post-turbo?
I hear that Dodge is giving you a puppy with every truck you buy, so you'll never have to walk home alone again.
2007 F250 6.0L PSD Lariat 4X4 - Dieselsite Coolant bypass Filtation -Bilstein Shocks-Blue fuel pressure upgrade spring-Rough Country Duel Steering Stabilizer-Fumoto Oil Drain Valve-HFCM Water Separator Drain Plug Upgrade-ARP studded
headviking is offline
post #9 of 51 (permalink) Old 09-07-2010, 01:10 PM
iracemx6's Avatar
I see 1050-1100 pulling my 28' enclosed race trailer on flat ground sustained
2003 F-250 CC FX-4...4x4
Tuned by INNOVATIVE
Industrial Injection Turbo
200cc sticks by CASSERLY
Zex-Nos
12.73...1/4 on 190's
iracemx6 is offline
post #10 of 51 (permalink) Old 09-07-2010, 01:30 PM
Can you tell me about your coolant filter ststem and where I can get one. Ed E
erskine_e is offline
