Help! Oil spouts on HP oil rails - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 09-01-2010, 12:26 AM Thread Starter
Exclamation Help! Oil spouts on HP oil rails
I have an 03 engine that has a major leak from the base of the swivel spout in the oil rail. The leak is so bad it will not start when hot. I have been unable to uncover any info from Ford or International as to any other options than a complete replacement rail. Ford quoted me $900 for the one rail and International quoted $800. Is there a socket to remove these plugs and a seal kit availible? The International diagram gives dimensions of the O-ring and lists it as a #118 O-ring. It seems down right crazy to spend so much on a complete replacement part when the only problem is one O-ring. I have searched online and in forums with little result. Any help would be much appreciated!
Dieseldan is offline
post #2 of 5 (permalink) Old 09-01-2010, 04:25 PM
Re: Help! Oil spouts on HP oil rails
There is a tool to remove the HP oil lines. I bought one and it works for the HP oil lines at the heads and at the HPOP. I do not know of a socket to remove the plugs. Most of that stuff is just metric fittings. I unplugged some of that stuff when I replaced my HPOP to see how it went together and I just used basic metric socket set. I do not know of a o-ring kit. I talked to ford dealership and they only sell the standpipes or oil rail. It really blows because its not the rails or lines that fail usually, but the o-rings. I am not 100% of the location of your oil leak. I will see if I have some pictures when I pulled my stuff apart to see if that might help.
2003 F250 6.0 CC LB
ARP's, Straight Pipe, IDP Tuned & FICM, Custom EGR Delete, Coolant Filter, PS Filter, Bypass Oil Filter, Upgraded Fuel Lines & Crossover, EGT & Fuel Pressure
tnadanzig is offline
post #3 of 5 (permalink) Old 09-02-2010, 04:30 AM
Sponsor
dalpilot's Avatar
You can find HP oil rails on ebay all the time for waaaaaayyyyyy cheaper.
dalpilot is offline
post #4 of 5 (permalink) Old 09-02-2010, 10:00 PM
It wasn't me
offroadinginaz's Avatar
I bet you could find the o-ring you need at Mcmastercar or some place like that if you get the demensions
Newman
A few Fords
Special Thanks to:
offroadinginaz is offline
post #5 of 5 (permalink) Old 09-02-2010, 11:50 PM
Damnkids Motorsports
Mdub707's Avatar
Send a message via AIM to Mdub707
I agree, Mcmaster has a huge selection of o-rings in a variety of materials as well.
DamnKids Motorsports
2006 F-250 6.0 4x4 Vegistroked
SCT Xcal2 w/Innovative Diesel Tuning 466/772 7/19/08
Black smoke don't mean it's broke... it means your tuning sucks!
Originally Posted by CSIPSD View Post
Paypal can go fuk themselfs... Buy me a beer the next time we meet.
Mdub707 is offline
