Pull the engine or not?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 08-28-2010, 02:28 PM Thread Starter
Snox49x's Avatar
Getting ready to do studs/egr delete AND a new clutch. Do not have a lift so this will be a cab on operation. I was wondering if it would be easier to just pull the engine to do the work? It's either that or do the engine stuff and then drop the trans to do the clutch. Thoughts?
05 F350 XLT 6.0 PSD 6 Speed w/ MBRP 4" turbo back exhaust, SCT by ID, 35" Toyo MT's on factory 20's, 1.5" leveling kit, F550 front springs.
Snox49x is offline
post #2 of 8 (permalink) Old 08-28-2010, 03:18 PM
STROKER6.04LIFE's Avatar
Re: Pull the engine or not??
Yes! That's what I did. Judy make shore to loosen th bolts on the trany and slide it back as far as you can. That inch helps. I put a dd southbend clutch on it. What clutch u going with?
Josh.
2003 6.0 RCLB
powermax
190cc
tuned by Eric and Matt
STROKER6.04LIFE is offline
post #3 of 8 (permalink) Old 08-28-2010, 03:47 PM
I Just Break Stuff
Pull it!!!!!! It's all right there in front of you after that. Easily fix anything on it right then. Sure makes 210 ft/lbs alot easier. Like Stroker said, tranny all the way back. It will wedge in there. Put a jack in the rear to hold half of it up.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
post #4 of 8 (permalink) Old 08-28-2010, 04:42 PM Thread Starter
Snox49x's Avatar
Your saying to pull the tranny back as far as I can correct? What else, besides the steps to do the heads will need to be done to remove the engine?
Gonna do a South Bend clutch. Cant decide on a single or double disk though.
Snox49x is offline
post #5 of 8 (permalink) Old 08-30-2010, 04:11 AM
WFO 4life
06 KR's Avatar
Take the Sheet metal off. Bumper, radiator and support, Fenders. Then you can get in there. Tilt motor back with trans to get the studs and head on. This is how the shop down the street from me does it. and they have a lift. Not sure why they do it like this but i saw it when it was all taken apart, and wow, you could do all the same stuff as if the cab was off. Anyway, that might work.
2011 F-350 Lariat
Silver on Black Chrome Edition
Roll-n-Lock......So far.
2006 King Ranch F-350
SOLD
"Sooner or later, you run out of SOMEBODY ELSES money."
06 KR is offline
post #6 of 8 (permalink) Old 08-30-2010, 04:34 AM
I Just Break Stuff
I pulled all the front clip off. Not that you have too, I just didnt want to scratch everything up. Dont need to pull the heads. Turbo, oil/fuel filter housing,FICM,intake,ect. Pretty much every acc off the top.Get your up pipes out of the way too. You can tie your downpipe up and to the pass side.Remember to recover your coolant from the a/c system. I pulled my a/c compressor and PS pump as well. Didnt want anything hanging up. I made a bar to pull it. Gets it down low. Your gonna need every inch of headroom you can get. The one that comes with your run of the mill hoist aint gonna work.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
Lowered 3 Inches
ARPs
Barder stage 3
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
irontx25 is offline
post #7 of 8 (permalink) Old 09-01-2010, 12:27 PM
Go with a dd clutch from southbend. If you don't you will have to pull the trans latter on down the road to put a new clutch in.
Josh.
2003 6.0 RCLB
powermax
190cc
post #8 of 8 (permalink) Old 09-10-2010, 12:42 AM
Not Winning.
6.0 p-stroke's Avatar
I just pulled the front clip apart when we pulled my engine, that way we only had to come up high enough to clear the oil pan, make sure to take off your up-pipes too.
Cooper
04 6.0 CCSB fx4
08 6.4 CCSB 4x4
Special thanks to:
Logan Schneider at CenTex Diesel Performance
830-885-6500
Originally Posted by Powerstroked162 View Post
Lets be honest here, how many times have you been on the receiving end of a "Cleveland Steamer"?
6.0 p-stroke is offline
