Head gaskets again - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 08-28-2010, 02:07 PM Thread Starter
Car Ramrod
06f250powerstroke's Avatar
Head gaskets again
truck is going in to the dealership for gaskets I just have a few questions
can i reuse my arp's
should i use different head gaskets other then stock
im going to get the heads decked
anything else i should be doing while there paying for it there being good about it they said i can add what ever else i want because its almost out of warrenty
thanks guys
64mm non vvt
190cc
FASS 95GPH
CFM
ARP's
IDP FICM
MBRP-4"
KMC Rockstars
BFG-KM2
pure performance 4 link
BD diesel Diverter Valve
06f250powerstroke is offline
post #2 of 14 (permalink) Old 08-28-2010, 03:41 PM
it's an 02 05 08
turbodiesel_02's Avatar
Re: Head gaskets again
you should be fine reusing the studs just get some arp lube,stock gaskets work fine if the heads are machined correctly. i would have the heads pressure checked and magnafluxed while there at the machine shop.i would also look into a regulated return fuel system,your injectors will thank you
2002 ext. cab lwb 4x4 7.3
05 front 08 rear conversion
4in lift,forged rod motor,tunes by tsd,bts trans,6.0 transcooler,6 autometers to watch,studs,springs,push rods,238cc hybrids,itp reg return,stealth hpop,tsd custom fuel system and sump,an so on
6.0's pay the bills and 6.4's soon..
turbodiesel_02 is offline
post #3 of 14 (permalink) Old 08-28-2010, 09:08 PM Thread Starter
Car Ramrod
I do have one on the truck
how do you check the block for being flat?
64mm non vvt
190cc
FASS 95GPH
CFM
ARP's
IDP FICM
MBRP-4"
KMC Rockstars
BFG-KM2
post #4 of 14 (permalink) Old 08-28-2010, 09:28 PM
I Just Break Stuff
Dealer ought to have a strait edge hanging on the wall, and know how to use it. And yes, you can reuse ARPs up to 5 times I believe. I would still get with ARP and see what the tolerance is for them. Then measure to make sure they're within spec. If I was almost out of warranty, I would make sure they got this right the first time. Good luck with it man.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
post #5 of 14 (permalink) Old 08-28-2010, 10:43 PM Thread Starter
Car Ramrod
thanks it 1K out of warrenty but they said i should be ok. I really want to make sure everything is done right this time i want to make some good power with this thing any input is great thanks guys
64mm non vvt
190cc
FASS 95GPH
CFM
ARP's
IDP FICM
MBRP-4"
KMC Rockstars
BFG-KM2
post #6 of 14 (permalink) Old 08-29-2010, 02:42 AM
SamW's Avatar
and the dealer doesnt care about the 155s or 64 turbo? I know a few dealers that are fine as long as your truck looks stock
2006 F250 CCSB
6.
SamW is offline
post #7 of 14 (permalink) Old 08-29-2010, 03:02 AM Thread Starter
Car Ramrod
diesel mech helped me do the mods says he can make it happen is there anythin else i shoul be doing while the cab is off
64mm non vvt
190cc
FASS 95GPH
CFM
ARP's
IDP FICM
MBRP-4"
KMC Rockstars
BFG-KM2
post #8 of 14 (permalink) Old 08-30-2010, 05:54 PM
motoxracer42's Avatar
the dealership has a straight edge but there specs arent to great. the heads need to be machined. it will just blow another gasket with ford specs. if they are covering it under warranty then its cool but im not to fond of fords work lol.
06 crew cab
06 reg cab
motoxracer42 is offline
post #9 of 14 (permalink) Old 08-30-2010, 07:51 PM Thread Starter
Car Ramrod
Im going to take the heads my self to a machine shop and have them checked over then it shouldnt blow again right?
64mm non vvt
190cc
FASS 95GPH
CFM
ARP's
IDP FICM
MBRP-4"
KMC Rockstars
BFG-KM2
post #10 of 14 (permalink) Old 08-30-2010, 08:38 PM
professional slacker
alwil's Avatar
Whos to say....they may or they may not, its kind of a crap shoot.
I do know you are one lucky sob getting warranty with all that aftermarket stuff bolted on there.
alwil is offline
