EGR delete.....CHEAP - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 29 (permalink) Old 08-26-2010, 02:10 PM Thread Starter
Sponsor
dalpilot's Avatar
Ok, somebody help me out with this. I have had my truck for nearly 8 years. 7 1/2 of those i have had my EGR unplugged. 6 1/2 of those I have had my EGR deleted, and I did it for $1.25. The egr cooler has a problem with failures after multiple heat cycles and when it fails, it leaks coolant into the intake. Its got two openings, one in the back from the exhaust, and one in the front going to the intake. I took it off, Cut out and welded the up pipe, (not necessary) and stuck a freeze plug in both ends. Been that way for 6 1/2 years. Conversing with a guy who makes EGR deletes the other day he tells me, that won't work??????
Ok, why? Lets say the EGR cooler fails, they fail on the inside leaking in to the intake right? Mine has a freeze plug there, it can't leak into it, nor can it leak out the back side. if it leaks, it simply fills the EGR cooler up, but its contained by the freeze plugs on each end. It simply becomes a reservoir. Its also still there in case DOT or your state does an inspection. Someone please tell me where my flaw is, because I certainly can't see it and I like the 1.25 plus my time price.
dalpilot is offline
post #2 of 29 (permalink) Old 08-26-2010, 02:13 PM
FNG
Dave's Avatar
Re: EGR delete.....CHEAP
I have only seen one of using that method fail. And thats because his freeze plug actually melted as a result of heat cycles
Dave G
06 F250 Lariat 4x4 leveled on 35s
4 inch flowmaster exhaust
Bulletproof diesel egr delete.
Bulletproof diesel FICM
Performance Machine & Manufacturing Coolant Filter Kit
ECM and FICM tuned by Bill at PHP SCT tunes from Gearhead, Innovative and Wildman
Dave is offline
post #3 of 29 (permalink) Old 08-26-2010, 02:15 PM Thread Starter
Sponsor
dalpilot's Avatar
I could see that as a "possibility" if you don't modify the up pipe, but freeze plugs are pretty tough.
dalpilot is offline
post #4 of 29 (permalink) Old 08-26-2010, 02:45 PM
Mpoage's Avatar
Where can I get freeze plugs at. I don't realy have the money for a delete kit right now
2007 Ford F-250 Lariat Outlaw 4X4
SCT X3 Tuned By Innovative Diesel
Straight Piped
Edge Insight
Mpoage is offline
post #5 of 29 (permalink) Old 08-26-2010, 02:47 PM Thread Starter
Sponsor
dalpilot's Avatar
Any auto parts store.
dalpilot is offline
post #6 of 29 (permalink) Old 08-26-2010, 03:00 PM
I Just Break Stuff
Nice!!!! Not really an argument there. Obviously it HAS been working. Name of he game is to eliminate the possibility of coolant getting into your intake via the egr system. Where is the problem? Cut it off, block it off, hack it up, reroute everything ........ Long as the end result is the same.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
post #7 of 29 (permalink) Old 08-26-2010, 03:03 PM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
If there is an issue with the freeze plugs couldn't comeone use something like 1/8" plate if they were worried?
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #8 of 29 (permalink) Old 08-26-2010, 03:19 PM
Sponsor
04stroker's Avatar
The freeze plugs work for me.
HOLDERS DIESEL PERFORMANCE
Building and flowing 6.0 injectors in house
holdersdiesel.com
04stroker is offline
post #9 of 29 (permalink) Old 08-26-2010, 03:24 PM
Ski Bum
J HO 22's Avatar
Send a message via Skype™ to J HO 22
I know a lot of people do it with no problems
502-316-8872
CALL OR EMAIL FOR PARTS PRICING
2005 EXCURSION
J HO 22 is offline
post #10 of 29 (permalink) Old 08-26-2010, 04:15 PM
Power Junky
Lubbockguy1979's Avatar
Same idea tim. Except I had a guy tig weld some stainless instead of the freeze plugs. I talked to a shop local to me when I lived in lubbock and they wanted to fill the cooler with jb weld and put freeze plugs.... I passed on that idea. Seen to much go wrong when you use jb weld.
Randy
2006 f250 4x4 lariat cc swb 6.0psd torqueshift elec tcase soon to have isspro gauges air/fire/tranny/ fuel pretty much stock
Lubbockguy1979 is offline
