Regulated Return or Airdog 2?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 08-26-2010, 05:25 AM Thread Starter
rollin coal!
Prew32's Avatar
So im getting everything together to do the studs on my truck and I wanna do a fuel system while the truck is apart. Im looking at Elite's stage 1 RR or an airdog 2. Any suggestion on which one to go with? Im also going to order a Garrett powermax turbo and eventually some 155cc injectors but that is the biggest sticks I will run since I tow pretty heavy. So what do ya'll recommend??
01 F350 CCLB 7.3 6 Speed with Luke clutch, 38R Turbo with Riffraff Billet Wheel, IH Bellowed up pipes, EBVP delete, hi flow outlet, Riffraff HPX, Riffraff intercooler boots, AFe Intake, Full Force 160cc single shots, Strictly Diesel RR fuel system, Hydra chip, 5.5" Fabtech lift, 18x10 Moto Metal 962's, 325/65/18 Cooper STT
Prew32 is offline
post #2 of 19 (permalink) Old 08-26-2010, 05:35 AM
Sponsor
04stroker's Avatar
Re: Regulated Return or Airdog 2??
Both.
HOLDERS DIESEL PERFORMANCE
Building and flowing 6.0 injectors in house
holdersdiesel.com
04stroker is offline
post #3 of 19 (permalink) Old 08-26-2010, 05:51 AM
I Just Break Stuff
If I had to choose one or the other........ Ide go with the AD II. Those 155s aint going to fail because you dont have a RR. Run low on fuel pressure and see what happens though. JMO. Good luck with it.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
post #4 of 19 (permalink) Old 08-26-2010, 11:51 AM Thread Starter
rollin coal!
Prew32's Avatar
Ya i was thinking the AD II would be plenty for my setup since im not going to be running a big set of sticks. My truck is pretty much a weekend driver and a tow rig for camping so I would hope the AD II would support the 155's
Prew32 is offline
post #5 of 19 (permalink) Old 08-26-2010, 12:34 PM
PursuitInterceptor
HeavyAssault's Avatar
Just the AD will do all you need with the 155's.
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #6 of 19 (permalink) Old 08-26-2010, 01:56 PM
Sponsor
dalpilot's Avatar
The AD II has a regulated return that runs back to the tank. The ADII will definitely help way more than the RR with your injectors. I don't know what size injectors they are, but elite recommends their rr system up to a stage 2 injector.
dalpilot is offline
post #7 of 19 (permalink) Old 08-26-2010, 02:07 PM
Stroker67's Avatar
Not to Derail the OPs thread, but would you need a RR with an airdog 2 and say 175 sticks?
Stroker67 is offline
post #8 of 19 (permalink) Old 08-26-2010, 02:11 PM
Sponsor
dalpilot's Avatar
The airdog 2 already returns fuel to the tank. IMHO if your gonna go over stock sticks, you need a fuel pump like the AD or FASS to keep your injectors happy. The best system would be a RR with the ADII.
dalpilot is offline
post #9 of 19 (permalink) Old 08-26-2010, 02:21 PM
SamW's Avatar
cant the fuel only be regulated at the regulator set to the lower pressure? if you had a regulated pump set to 55 psi and a regulator set to 60 psi on the motor wouldnt the regulator on the motor never open? in my opinion all you need is a regulated pump, and drill out the banjo bolts or get upgraded lines from the bowl to the heads and mabue a crossover line in the back.
2006 F250 CCSB
6.
SamW is offline
post #10 of 19 (permalink) Old 08-26-2010, 02:26 PM
Sponsor
dalpilot's Avatar
I would NOT drill out the banjo bolts. Buy oversize lines and fittings, but I have heard of several breaking in the heads, and that is a nightmare.
dalpilot is offline
