oil port? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 08-23-2010, 06:53 PM Thread Starter
Back in Black
stroken's Avatar
oil port?
installing guages on my buddies 06 6.0
where do you put the sender for oil temp?
2009 F-250 ccsb black/black
Lowered 4400lb spring, 20x10 MM962, Nitto 420, traction bars, 5" exhaust 7" MBRP black stack, SCT - Innovative tunes, IDP cold side IC pipe, MPD trans. Blacked outtttt
stroken is offline
post #2 of 5 (permalink) Old 08-23-2010, 07:07 PM
freeride808's Avatar
Re: oil port?
get a tapped oil filter cap.
2004 F-350 DRW KR, Half Spartan/ Half Elite Motor with custom internals, 155 injectors from RCD (Spartan),Elite VGT-SS Turbo (now it is a paper weight
) replaced with Power Max, ITP RR, Airdog II adj, Banks CAC tubes and intercooler, Amsoil Bypass oil filter, Elite EGR Delete, Elite Head Studs, AFE Stage 3 intake, 4 exhaust
freeride808 is offline
post #3 of 5 (permalink) Old 08-23-2010, 07:35 PM
40 lug nuts
Snake's Avatar
Re: oil port?
+1
There are aftermarket aluminum caps available that already tapped.
BULLETPROOF DIESEL
Biofuels Technologies
1A Auto
2005 F-250
Snake is offline
post #4 of 5 (permalink) Old 08-23-2010, 11:58 PM
Attention Whore
UNBROKEN's Avatar
Re: oil port?
Or you can use the oil pressure test port
Spending money I don't have on crap I don't need to impress people I don't know.
UNBROKEN is offline
post #5 of 5 (permalink) Old 08-24-2010, 12:10 AM
Extended Power's Avatar
Re: oil port?
Or drill and tap the top cover of the oil cooler. You gotta look close...I circled it in red.
2003 F-350 KingRanch 4x4
Extended Power is offline
