Fire Ring Heads - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 08-20-2010, 02:41 AM Thread Starter
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
Lightbulb Fire Ring Heads
Pro and Cons ? Whos Done it? Gains or head aches ? Why do it ?
Discussion Starts
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
post #2 of 22 (permalink) Old 08-20-2010, 02:45 AM
<-- Got Air ?
Craig@MPD's Avatar
Re: Fire Ring Heads
heard of alot problems with fire ringed heads never ran them just heard they dont hold up good
post #3 of 22 (permalink) Old 08-20-2010, 02:49 AM Thread Starter
The Unseen Mod
RescueF250's Avatar
Re: Fire Ring Heads
What were the problems ? improper install ? not seating correctly ? Not center
03 Rescue is Dead
post #4 of 22 (permalink) Old 08-20-2010, 02:51 AM
<-- Got Air ?
Craig@MPD's Avatar
Re: Fire Ring Heads
lot of people would blow the ring into the cylinders or the water jackets
with a flat surface and h11s theres no need for anything else
post #5 of 22 (permalink) Old 08-20-2010, 05:30 AM
Oil anyone?
The Oiler's Avatar
Re: Fire Ring Heads
Heard also that they dont like a lot of heat cycles, like in the DD sence. But i cant confirm this,just heard about it.
Pull truck:
96' F-250 ex-cab
Swamps oil and fuel
T-bars,airbags, 5in stacks
getting back on the road soon.
Now have a s366 from Swamps now.
01' xlt excursion with a 7.3
all stock for now and gets 18mpg
The Oiler is offline
post #6 of 22 (permalink) Old 08-20-2010, 05:37 AM
WFO 4life
06 KR's Avatar
Re: Fire Ring Heads
Pinched ring gaskets on install, and seapage after a lot of heat cycles. Thats when I said no thanks. ARP's and stock head gaskets or black onyx.
2011 F-350 Lariat
Silver on Black Chrome Edition
Roll-n-Lock......So far.
2006 King Ranch F-350
SOLD
"Sooner or later, you run out of SOMEBODY ELSES money."
06 KR is offline
post #7 of 22 (permalink) Old 08-20-2010, 12:34 PM
Sponsor
dalpilot's Avatar
Re: Fire Ring Heads
When I had my motor built, the shop was adamant against them. Flat surface, and good studs, gives a lot more clamping force surface area.
dalpilot is offline
post #8 of 22 (permalink) Old 08-20-2010, 03:24 PM
Extended Power's Avatar
Re: Fire Ring Heads
Why not check to see what the guys that are making over 800, 900, and 1000hp are doing?
NONE of them are using fire rings...
2003 F-350 KingRanch 4x4
Extended Power is offline
post #9 of 22 (permalink) Old 08-20-2010, 04:28 PM Thread Starter
The Unseen Mod
RescueF250's Avatar
Re: Fire Ring Heads
I know Ivan, I just do random discussions about things, instead of the usual exhaust egr delete question. Also its a quick reference if someone ask, they can search n view the thread.
03 Rescue is Dead
post #10 of 22 (permalink) Old 08-20-2010, 09:16 PM
6.0 money pit
smokinstroker's Avatar
Re: Fire Ring Heads
so far i havent had a problem with mine, they are holding just fine. but havent put that many miles on the truck to tell.
smokinstroker is offline
