White smoke - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 08-19-2010, 03:54 PM Thread Starter
White smoke
I have 2005 excursion 6.0. I just had it studded, decked, egr delete kit, and a new oil cooler. Ive noticed that it seems to blow white smoke when I start it and it goes away once it gets warmed up. Should I be concerned?
Also it seems like since I had this work done it seems like I have lost a little power.?.?
strokedGator is offline
post #2 of 8 (permalink) Old 08-19-2010, 04:06 PM
FNG
Dave's Avatar
Re: White smoke
What PCM flash is on the truck?
Dave G
06 F250 Lariat 4x4 leveled on 35s
4 inch flowmaster exhaust
Bulletproof diesel egr delete.
Bulletproof diesel FICM
Performance Machine & Manufacturing Coolant Filter Kit
ECM and FICM tuned by Bill at PHP SCT tunes from Gearhead, Innovative and Wildman
Dave is offline
post #3 of 8 (permalink) Old 08-20-2010, 04:52 AM
your mom
RMPowerstroke's Avatar
Re: White smoke
how much smoke at start up
f350 king ranch dubed. ol ranchero thanks to wayne
04 cc/lb 9inch lift C-6 built converter custom revs manual valve body r servo. powered by 12v cummins p-pump 4k gvs custom lasered dlv pump work, 5x16 sticks, singler charger for now, airdog150, its on meth lots of custom junk. hids road armor bumper and im truck broke
06 f-150
RMPowerstroke is offline
post #4 of 8 (permalink) Old 08-20-2010, 04:58 AM
jdgleason's Avatar
Re: White smoke
Depending on the PCM flash as stated above, it could be injectors. There are spool valves in the injectors that can stick when they are cold, and open once warm which can cause hard cold starts and smoke at start too
'09 F350
-JD
jdgleason is offline
post #5 of 8 (permalink) Old 08-24-2010, 12:48 AM
It wasn't me
offroadinginaz's Avatar
Re: White smoke
Did it have a blown EGR cooler before all the work was performed?
Newman
A few Fords
Special Thanks to:
offroadinginaz is offline
post #6 of 8 (permalink) Old 08-24-2010, 01:06 AM
Re: White smoke
Might be some excess water in the exhaust that just needs time to clear, or an untested cooler may have been re-installed
silvrcummns is offline
post #7 of 8 (permalink) Old 08-24-2010, 04:29 PM
SamW's Avatar
Re: White smoke
might want to check your ficm voltage as well.
2006 F250 CCSB
6.
SamW is offline
post #8 of 8 (permalink) Old 08-25-2010, 03:25 AM
BigBlack03's Avatar
Re: White smoke
Sorry to steal the post but when i had my icp sensor done the dealership reflashed my computer last year and it has been starting to lack in power and blow a little black smoke. I took my Edge off and it has been acting up since then. Just curious if anyone has any input...
BigBlack03 is offline
