First post...another injector question. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 08-13-2010, 08:16 PM Thread Starter
coach's Avatar
Im runnin a II hybrid 1 turbo with stock injectors and wanted to upgrade. Dont pull much but want that option. Really wanted 190s but after research dont know if my turbo will clean them up and dont want a real smokey truck. Does the 8 hole tips make 190s clean up better? Who sells the 8 hole tips?
coach is offline
post #2 of 19 (permalink) Old 08-13-2010, 08:38 PM
BRING DA AMBALAMPS
stroke of luck's Avatar
Re: First post...another injector question.
you can always get the 190's and have your tuner pull some fuel out of them. when you upgrade to a bigger turbo, you can turn em back up.
2005 CC FX4...compounds and everything else that goes with em.
stroke of luck is offline
post #3 of 19 (permalink) Old 08-13-2010, 09:02 PM Thread Starter
coach's Avatar
Thats what i was thinkin...plus if i decide to later to go with twins i dont have to change um. I called II today they said they dont have the 8 hole tips.
coach is offline
post #4 of 19 (permalink) Old 08-13-2010, 09:07 PM
BRING DA AMBALAMPS
elite has 8 hole tips. and FWIW, I have 190's and I'll be pairing it up with the Garrett Powermax which isn't all that big of a turbo. I've heard that set up does just fine...
post #5 of 19 (permalink) Old 08-13-2010, 10:27 PM Thread Starter
coach's Avatar
lookin forward to hearin how it runs!
coach is offline
post #6 of 19 (permalink) Old 08-14-2010, 09:27 PM
Sponsor
dalpilot's Avatar
I have 190's, and a Beans 65mm and it DOES NOT clean up at all. Ryan Casserly sells 8 hole tips. I will be getting the tips soon, and probably stepping down to smaller sticks. Towing the race trailer on flat ground at 70MPH = 1100 degrees EGT and tons of smoke. If you tow, 190's are big.
dalpilot is offline
post #7 of 19 (permalink) Old 08-15-2010, 08:01 PM
GOOSEKILLER's Avatar
155's would be a good match with your turbo.
2001 2500 4x4
Built 12 valve
TNT Performance
GOOSEKILLER is offline
post #8 of 19 (permalink) Old 08-16-2010, 04:10 AM Thread Starter
coach's Avatar
Is there any vgt that will clean up 190s?
coach is offline
post #9 of 19 (permalink) Old 08-16-2010, 01:54 PM
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
VGT HO would probably clean up 190s close. If you get twins, your gonna need more then 190's thats my opinion.
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
post #10 of 19 (permalink) Old 08-16-2010, 05:43 PM Thread Starter
coach's Avatar
My biggest problem is i bought parts before i found this place! Would love to update my turbo just cant justify it with less than 10000 miles since i bought it.
coach is offline
