FASS pressure problem? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 08-11-2010, 12:30 AM Thread Starter
so my FASS has been loosing pressure over the past few months..... it was down to 50 psi at idle.... dipping to 48 at wot. I called FASS,and they told me to shim the spring at the return fitting... so when I removed the fitting to find the ball was kinda pulled up into to spring a little bit...... I turned the ball so it rode on top of the spring....... I shimmed the back of the spring with a 5/8th inch washer, and I now have 68 psi steady, it will dip sometimes to 65 but it stays up there pretty good now.... just thought I would pass it along just in case anyone else is having the same issue.
03 F-250 207000 miles, Mad Turbo Werks Stage 1 Turbo, RCD155 injectors 100% Nozzles, 150/180 FASS, FCDP EGR delete, ARP Headstuds, OEM head gaskets, Diesel Site coolant filter kit, SCT Tunes, Hellmans Sump, 4inch Magnaflow Exhaust, 6.4 banjo bolts, AR-9100 Oil Treatment, 58v FICM
F-250-Owner is offline
post #2 of 3 (permalink) Old 08-11-2010, 03:13 AM
6.0 money pit
smokinstroker's Avatar
Re: FASS pressure problem?
68 psi is great for your injectors....
smokinstroker is offline
post #3 of 3 (permalink) Old 08-11-2010, 12:49 PM Thread Starter
awwww it seems i have an E-stalker..... stay in the other thread, no one asked for your comments on MY injectors you nozzle. This is a thread about my FASS fuel pressure issues...... so if you have a comment on FASS fuel pressure issues, feel free to post.
