Looking for a new turbo - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 08-09-2010, 10:58 PM Thread Starter
Work&Play's Avatar
My turbo started to screech on Sat.
I'm looking at the Garrett Powermax GT3788V.
Will this work on a DD that weighs 12,000 lbs and also tows a trailer that can be another 10,000.
I have stock sticks.
Will this help to lower my EGT's.
What else do I need to install it?
Thanks and sorry for all the ?
Andy 2007 4X4 F350,6.0 PSD, Lariat, CC, DRW, 9' Knapheide body, stainless steel ladder rack, SCT with custom tunes, Banks turbo back, ARP's, ITP RR, Airdog II, Powermax with Billet Wheel, Firestone air bags, Autometer gauges( pyro,fuel pres,water temp,boost,trans temp), CCV mod.
Work&Play is offline
post #2 of 20 (permalink) Old 08-09-2010, 11:39 PM
professional slacker
alwil's Avatar
Re: Looking for a new turbo
I think there are people out there running them with stock stix...also I am pretty sure its a direct bolt on turbo
alwil is offline
post #3 of 20 (permalink) Old 08-10-2010, 01:14 AM
<-- Got Air ?
Craig@MPD's Avatar
Check your uppipe first to see if the bellows are blown out
post #4 of 20 (permalink) Old 08-18-2010, 11:34 PM
It wasn't me
offroadinginaz's Avatar
It sounds like it would be a good option for you but I don't have any expierence with it.
Do you monitor your oil temps? Rolling around at 12K all the time has to work you engine pretty hard.
Newman
A few Fords
Special Thanks to:
offroadinginaz is offline
post #5 of 20 (permalink) Old 08-19-2010, 12:45 AM
SamW's Avatar
should work fine, I would honestly stay with a stock turbo unless you are planning to upgrade injectors when towing that much. usuially the best tow setups are as close to stock as possable
2006 F250 CCSB
6.
SamW is offline
post #6 of 20 (permalink) Old 08-19-2010, 01:13 AM
Extended Power's Avatar
Yip....It's worked for you so far...why mess with it?
Just because it's still a VGT doesn't mean it's gonna spool as fast as your stock turbo...it WILL have lag, and the first time you need that instant response and it's not there....you are gonna kick yourself in the a$$ for changing it.
2003 F-350 KingRanch 4x4
Extended Power is offline
post #7 of 20 (permalink) Old 08-19-2010, 02:15 PM
douglash's Avatar
I just put that turbo in my excursion. He is right there is a little lag but not bad at all. I have stock sticks and use IDP tow tune and it runs great, I have no smoke even under wot now. My egts are about 100-150 lower crusing and about the same towing. I have a longer trip planned for labor day so I can get better account. I do hear the turbo now so if you don't like that you might look at another brand.
2004 EB Excursion
douglash is offline
post #8 of 20 (permalink) Old 08-19-2010, 03:26 PM
BCPSD's Avatar
I have the powermax on my 06 with stock stick and stock fuel system. IMO opinion tuning is everything on these. The lag isn't bad and daily driving is enjoyable. It took a bit of time to relearn how to drive as far as the shift points and where its spooled since its different from a stock turbo. But when you learn that its a blast to drive.
Towing with the powermax is definetly less capable than the stock turbo. It feels like it has less power with the tow tune then a stock truck. I tow my 8900 lbs camper with it and its the only time I wish I still had a stock turbo. EGT's are still managable but the power just isn't there. Before I could pass vehicles on a two lane road without any concern pulling my camper, but now I have to get a running start and still kind iffy on if I can pass in time.
06 6.0 Powerstroke Crew Cab
S&B Intake
MBRP exhaust
Powermax
TSD tunes
BCPSD is offline
post #9 of 20 (permalink) Old 08-19-2010, 03:29 PM
And being that he will be towing 10,000-12,000 pounds...it would make it that much worse...
Stay with the stock turbo...you won't regret it.
post #10 of 20 (permalink) Old 08-19-2010, 05:01 PM
BCPSD's Avatar
I would have to agree with this. I live in a pretty flat hilless area. I couldn't imagine towing with this thing going up a good sized hill or mountain.
S&B Intake
MBRP exhaust
Powermax
TSD tunes
BCPSD is offline
