Additives - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 08-08-2010, 05:45 PM Thread Starter
morseranch's Avatar
Additives
I was just wondering if there were any suggestions about fuel and oil additives for the Powerstroke. I'm a firm believer in Slick-50 for my gassers but I'm not sure how it'll do in a Powerstroke. As for fuel additives, I've tried "Dieselkleen" but it seems to make my performance and MPG worse. Any suggestions?
Mark
05 F-250 Lariat
6" lift W/ 35's
Stock W/ Sinister coolant filter system, BPD 6 phase FICM, blue spring upgrade
51 gal Titan fuel tank
Edge Insight CS
morseranch is offline
post #2 of 16 (permalink) Old 08-08-2010, 05:50 PM
it's an 02 05 08
turbodiesel_02's Avatar
Re: Additives
i have been using this additive from ford and it seems to help out not sure if its cost effective or not as i got it for free.
2002 ext. cab lwb 4x4 7.3
05 front 08 rear conversion
4in lift,forged rod motor,tunes by tsd,bts trans,6.0 transcooler,6 autometers to watch,studs,springs,push rods,238cc hybrids,itp reg return,stealth hpop,tsd custom fuel system and sump,an so on
6.0's pay the bills and 6.4's soon..
turbodiesel_02 is offline
post #3 of 16 (permalink) Old 08-08-2010, 06:09 PM
Re: Additives
I've Been using 2 stroke oil, seems to work pretty good
2005 f250 fx4 lariat
egr delete, head studs, edge cts
mbrp 4" straight pipe. sct tuned by eric
future mods..
190 casserly injectors
garret powermax,
looking for some 190s pm if you have some
kenny7231 is offline
post #4 of 16 (permalink) Old 08-08-2010, 07:55 PM
Still learning
bad moose's Avatar
Re: Additives
I like Howe's the best. Power Service is ok but besides lubrication I haven't seen any other benefits. As for oil you will learn that Rev-X is well liked by those that use it. I haven't tried it yet but getting closer to trying it.
03 F250 King Ranch
SCT tuned by Eric @ Innovative, Exhaust, and Air Raid filter
EGR Deleted
Still to slow
bad moose is offline
post #5 of 16 (permalink) Old 08-08-2010, 08:09 PM
diesel and nothing else
amarillo250's Avatar
Send a message via Yahoo to amarillo250
Re: Additives
Fuel Additive - Powerstroke Nation
Read and then you get a better point of view.
06 F250 CCSB, still working on it
Thanks to FCDP and all the guys on here for their help.
amarillo250 is offline
post #6 of 16 (permalink) Old 08-09-2010, 03:14 AM
Diffrent Strokes
orrwhat's Avatar
Re: Additives
Stanadyne fuel treatment is about the best thing you can get for the 6.0. Ive heard that Rev-X is very effective for the oil treatment. You dont want to add anything to the engine that uses PTFE because it will wipe out your injectors. Also make sure you use the correct oils and Yellow antifreeze.
orrwhat is offline
post #7 of 16 (permalink) Old 08-09-2010, 10:08 AM
sixOHsucker's Avatar
Re: Additives
Is the yellow antifreeze really important? When I did my EGR delete I used the all makes all models stuff. Bad idea?
sixOHsucker is offline
post #8 of 16 (permalink) Old 08-09-2010, 01:15 PM
Re: Additives
The usual anti-freeze has long life additives they plug your system.
Look into the fluid section on here you find everything you need.
post #9 of 16 (permalink) Old 08-09-2010, 05:23 PM
Diffrent Strokes
orrwhat's Avatar
Re: Additives
It has to be the correct Motorcraft antifreeze. The regular stuff will cause cavitation and eat a hole the the cylinder lining.
orrwhat is offline
post #10 of 16 (permalink) Old 08-09-2010, 08:53 PM
Reppin' the 6.4L
SickStroke6.0's Avatar
Re: Additives
I used the Cetane Booster from Ford. They know these engines better than anyone, and it is made specifically for Powerstrokes. And it's cheaper than the Power Service stuff I used to use.
Blake
Looking for a second 6.4L....
2008 F-250 CCSB King Ranch 6.4L
4" Rough Country Lift, Dual Steering Stabilizers, 20x10" XD Diesels, 35x12.50x20" Mickey Thompson MTZ's, Line-X, 15% Tint, MBRP 4" Cool Duals w/ 6" Tips, S&B Intake, Flo-Pro EGR Delete and Elbow, MBRP CAC Tube
SickStroke6.0 is offline
