rebuilding my 6.0 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 08-08-2010, 05:57 AM Thread Starter
379cat's Avatar
rebuilding my 6.0
getting ready to start putting this thing back together, after having the block decked and the pistons shaved and coated. this will be my first time putting a 6.0 together other then doing the head gaskets last time, any tips/tricks i should know putting the bottem end together . also i read that ARP wants us to only go to 210 lbs on the studs now, is this what you all are doing or are u still using 245 lbs? i have the new lube by the way. any advice to save me trouble would be great! thanks in advance....
99 ford superduty started its life with a 5.4 triton, now its got a 05 6.0 powerstroke in it , BD thruster turbo, RCD 175 cc injectors, ARP studs, black onyx gaskets inovative tunes. homade egr delete. homade RR fuel system fass 150 pump, suncoast trans kit ran 13.4 fuel only
379cat is offline
