What would be the perfect single turbo.... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 08-03-2010, 03:44 AM Thread Starter
Extended Power's Avatar
If you could spec it out completely, and STILL use it in a twin turbo application?
I think if a fella could use "Unobtainium" for the compressor wheel, and make the inducer 64mm....and the exducer about a 91mm....then make the turbine inducer saaaayy....79-80mm and the exducer 71mm...maybe with a clipped wheel, or a wastegate...
Then make the turbine A/R about a 12cm....or .65/.70
What if we could use the up-pipes and manifold from a 7.3L, instead of the silly "Y" pipe manifold we have on the 6.0L...
Oh...and maybe use stainless steel for the turbine housing, or ceramic coat the bugger...
Any other idea's???
Discuss....
2003 F-350 KingRanch 4x4
Extended Power is offline
post #2 of 23 (permalink) Old 08-04-2010, 02:13 AM Thread Starter
Re: What would be the perfect single turbo....
wow...105 views, and no comments at all.
post #3 of 23 (permalink) Old 08-04-2010, 02:16 AM
gone6.0's Avatar
04 F250 4x4, 2.5 front level kit, 4" MBRP, Banks Inter cooler, Home made coolant filter, Insight monitor, Nathan K5l horns, ten gal air tank, harpooned, Fumuto valve, custom stripes and decals.
gone6.0 is offline
post #4 of 23 (permalink) Old 08-04-2010, 02:25 AM
psn local
silver 64mm
smokin6.0psd is offline
post #5 of 23 (permalink) Old 08-04-2010, 02:28 AM
moore20017.3's Avatar
A vgt larger than the stock unit that does not fail.
2008 F-250 SCLB Larait.
moore20017.3 is offline
post #6 of 23 (permalink) Old 08-04-2010, 02:30 AM
motoxracer42's Avatar
Any other idea's???
Discuss....
well i guess ill join in lol. non gated with a 12cm would be a no no. drive pressure would get up there. clipping the exhaust wheel works but i know alot of companys think its ghetto lol. i think the best single turbo is stock .
i will be testing single turbos soon in another truck. ill let you guys know how things work out.
06 crew cab
06 reg cab
motoxracer42 is offline
post #7 of 23 (permalink) Old 08-04-2010, 02:31 AM Thread Starter
But if you go too big on the compressor...then you have surge issues.
No doubt...there is nothing that spools as fast as a VGT type turbo...
I also can't STAND the whistle of a VGT style turbo anymore....
post #8 of 23 (permalink) Old 08-04-2010, 02:35 AM
psn local
whistle delete mod
post #9 of 23 (permalink) Old 08-04-2010, 03:18 AM
lubeowner's Avatar
Put on a modded intake and I bet all your opinions of turbo sizing will change!
Jeremy Johnson
Search "lubeowner" on youtube for many truck pulling videos.
dieseldr.net
We build Powerstroke pulling trucks.
lubeowner is offline
post #10 of 23 (permalink) Old 08-04-2010, 03:24 AM
<-- Got Air ?
Craig@MPD's Avatar
silver 64 is a very very nice turbo on the 6.0 makes a solid 585hp-617hp as it did on nates truck
with a manifold you could probly make 650 range i would believe
