No smoke - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 08-01-2010, 01:41 AM Thread Starter
gone6.0's Avatar
No smoke
What would be the best set up for a close to 500hp with no smoke or very little?
04 F250 4x4, 2.5 front level kit, 4" MBRP, Banks Inter cooler, Home made coolant filter, Insight monitor, Nathan K5l horns, ten gal air tank, harpooned, Fumuto valve, custom stripes and decals.
gone6.0 is offline
post #2 of 22 (permalink) Old 08-01-2010, 01:49 AM
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
Re: No smoke
Larger turbo less injector probably, powermax turbo n a set of 155s should get u pretty close if not then 175. That might put you over 500
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
post #3 of 22 (permalink) Old 08-01-2010, 01:53 AM Thread Starter
gone6.0's Avatar
Re: No smoke
I am stock now except for Banks intercooler, Eric's extreem street tune and studs. gonna do the egr delete soon, and new airdog fuel pump.
gone6.0 is offline
post #4 of 22 (permalink) Old 08-01-2010, 03:08 AM
The Unseen Mod
RescueF250's Avatar
Re: No smoke
Your gonna smoke a lil when ur under the turbo at low boost but it can cleanup afterwards, ill post a video of mine on a dyno. Also it does smoke but under regular driving I can control that.
03 Rescue is Dead
post #5 of 22 (permalink) Old 08-01-2010, 03:14 AM
Re: No smoke
what about your avatar pic, are you under the turbo :)
halerazor is offline
post #6 of 22 (permalink) Old 08-01-2010, 03:18 AM
Turbo99's Avatar
Re: No smoke
I had some 190's and 64mm non VGT and after some tweaks on the tuning it was very low smoke and 580's hp
_____________________________________________
Jeremy
08'F250 CCSB 4x4 ALL White except whats Black!!
10' Camaro 2SS LS3 All White except whats Black!! Supercharged 682 RWHP 10.80 @ 131mph
Turbo99 is offline
post #7 of 22 (permalink) Old 08-01-2010, 03:51 AM
fordfan30's Avatar
Re: No smoke
Whos sticks turbo and tune were you running? Those are impressive numbers and I am eyeing a similar setup.
To the OP run compounds
fordfan30 is offline
post #8 of 22 (permalink) Old 08-01-2010, 04:33 AM
psn local
Re: No smoke
190's and twins should do it. are you wanting no smoke at wot or just none at all? my 175's don't smoke bad at all unless under the turbo but once spooled smoke free at even at wot.
smokin6.0psd is offline
post #9 of 22 (permalink) Old 08-01-2010, 04:38 AM
The Unseen Mod
RescueF250's Avatar
Re: No smoke
yup 0 boost, go pedal to the ground no holdin bck. Then it cleared up WOT
03 Rescue is Dead
post #10 of 22 (permalink) Old 08-01-2010, 04:44 AM
Re: No smoke
if your the only the one laughing at me, why are there 2 smiley's?????
