Have any of the 6.0 guys run either a bosch 044 pump or a walbro pump? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 07-23-2010, 02:35 AM Thread Starter
I used to have a 7.3 and I built the whole fuel system from rhe pick up to the reg return. Well I still have a bosch 044 from my old truck as well as my aeromotive reg. But I was wondering if an 044 or a walbro has enough flow for a 6.0. The walbro comes into question bc of my buddies truck if so we will make the fuel systems identical minus using a walbro on his cause of cost. Just curious trying to cut corners cause I have some parts from my old truck. Thanks
TDK8610 is offline
post #2 of 5 (permalink) Old 07-23-2010, 05:27 AM
professional slacker
alwil's Avatar
Re: Have any of the 6.0 guys run either a bosch 044 pump or a walbro pump?
What kind of pressue does that pump put out, I have heard of people running the walbro pump but not the other one.
alwil is offline
post #3 of 5 (permalink) Old 07-23-2010, 05:31 AM Thread Starter
Both are capable of mid 70's if not maby a bit more. I just didnt know if they have enough flow?
TDK8610 is offline
post #4 of 5 (permalink) Old 07-23-2010, 05:33 AM Thread Starter
They do quite well on a 7.3 set at 65 to 70 psi with a set of 200+ cc a codes
TDK8610 is offline
post #5 of 5 (permalink) Old 07-23-2010, 03:58 PM
PGreenSVT's Avatar
Well the "044" is a pretty beefy pump. If it held up under the post above I would give it a try. I use an "044" on my 500+ rwhp Cobra.
Deceased Member RIP Mitch the PSN crew
05 F250 Harley Davidson long bed, Airaid CAI, CFM+ Largemouth in CF with pipe kit, zoodad mod, 4" turbo back Magnaflow duals with kitty delete and 6" tips, Edge Insight monitor with EGT, SCT with tunes by Eric; DJ's billet oil filter cap feeding a Gulf Coast bypass filter, 275/65/20 Nitto Terra Grapplers, 03 turbo whistling a happy tune.
PGreenSVT is offline
