FASS or Injectors? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 07-22-2010, 02:44 AM Thread Starter
Car Ramrod
06f250powerstroke's Avatar
FASS or Injectors?
my truck is now sputtering when i acellerate and when i stop the fass pump seems to be making some wierd noises my fuel pressure gauge that is hooked to the regulated return is doing a bit of dancing when the truck is under load and also the truck seems to sound a bit different at idle any thoughts along with it puking coolant when i make a 1/4 mile pass could all this be linked? any help would be great thanks again guys
64mm non vvt
190cc
FASS 95GPH
CFM
ARP's
IDP FICM
MBRP-4"
KMC Rockstars
BFG-KM2
pure performance 4 link
BD diesel Diverter Valve
06f250powerstroke is offline
post #2 of 31 (permalink) Old 07-22-2010, 03:07 AM
SamW's Avatar
Re: FASS or Injectors?
A bad FASS pump wont cause puking. mine fed 190s all day at 55 psi no matter how I drove. I would bet you have a headgasket issue. Did it always puke with the 155s? usuially when you add something such as big injectors, its gonna puke a little to where its happy but that shouldnt last long. could just be a bad cap. how bad is the puke? what does your fuel pressure range?
2006 F250 CCSB
6.
SamW is offline
post #3 of 31 (permalink) Old 07-22-2010, 03:07 AM
BRING DA AMBALAMPS
stroke of luck's Avatar
well I'll start with the obvious....how full is your fuel tank?
with my FASS, it starts bucking and cutting out at around a 1/4 tank. my pickup tube probably needs to be a bit longer...
2005 CC FX4...compounds and everything else that goes with em.
stroke of luck is offline
post #4 of 31 (permalink) Old 07-22-2010, 03:10 AM
Stroker67's Avatar
for the puking issue, i would start with a new cap, i think its like 9 bucks.
Stroker67 is offline
post #5 of 31 (permalink) Old 07-22-2010, 03:24 AM Thread Starter
Car Ramrod
Thanks guys I'l get a new one tmr. just went to town and back 30mins and the level did not change in the bottle could have just been over full and it didnt like the WOT runs. as for the fuel presure it goes to 60psi at cold start up then drops to 58ish when its working good. now its starts at 58 then when you put the truck under load it will dance between 42 and 58. i drained the water separater today to see if there was water then let it prime its self back up to 58psi could it have air trapped in the system you think?
64mm non vvt
190cc
FASS 95GPH
CFM
ARP's
IDP FICM
MBRP-4"
KMC Rockstars
BFG-KM2
post #6 of 31 (permalink) Old 07-22-2010, 03:43 AM
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
Could have been sucking air, that's why I went with a sump pump I don't have to worry about that
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
post #7 of 31 (permalink) Old 07-22-2010, 03:54 AM Thread Starter
Car Ramrod
tank is at 3/4 full would the air not clear its self out after 30mins of driving?
64mm non vvt
190cc
FASS 95GPH
CFM
ARP's
IDP FICM
MBRP-4"
KMC Rockstars
BFG-KM2
post #8 of 31 (permalink) Old 07-22-2010, 04:07 AM
CompD Mod
Santa Gertrudis's Avatar
Yep. That fixed my puking problem on my old truck!
BBC-
2010 F-250 6.4L ,CCSB, 4x4, Black
TruckSourceDiesel
DerangedPerformance
FirstCoastDieselPerformance
SpartanDieselTechnologies
Santa Gertrudis is offline
post #9 of 31 (permalink) Old 07-22-2010, 10:36 AM
I have the FASS and a sump.... and will still lose fuel pressure at around 1/4 tank due to sloshing on the country roads I drive on. My FASS used to run 58 to 59 psi all the time, now it stays at 55 psi. I stretched the return spring, did the 6.4 banjo bolts, and deleted the engine mounted fuel filter and it holds good at 55. If I see it dropping lower and holding steady at a lower number, I will call FASS and see what they say.
03 F-250 207000 miles, Mad Turbo Werks Stage 1 Turbo, RCD155 injectors 100% Nozzles, 150/180 FASS, FCDP EGR delete, ARP Headstuds, OEM head gaskets, Diesel Site coolant filter kit, SCT Tunes, Hellmans Sump, 4inch Magnaflow Exhaust, 6.4 banjo bolts, AR-9100 Oil Treatment, 58v FICM
F-250-Owner is offline
post #10 of 31 (permalink) Old 07-22-2010, 04:14 PM
Stroker67's Avatar
Got a link to the sump? i would like to consider this one day, whenever i can get the money for an Airdog 2.
