whats the best way to torque ARP bolts - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 07-22-2010, 02:06 AM Thread Starter
379cat's Avatar
well i will be putting my block together soon, some say do 3 step to 245 foot pounds. then iv also been hearing about torque to i think 90 pounds then go 90 degrees? i might have that wrong. can i re use my rod and main bolts?
99 ford superduty started its life with a 5.4 triton, now its got a 05 6.0 powerstroke in it , BD thruster turbo, RCD 175 cc injectors, ARP studs, black onyx gaskets inovative tunes. homade egr delete. homade RR fuel system fass 150 pump, suncoast trans kit ran 13.4 fuel only
379cat is offline
post #2 of 12 (permalink) Old 07-22-2010, 02:08 AM
King Dingaling
TANK'S 250's Avatar
Re: whats the best way to torque ARP bolts
bottom of post #2
TANKS Library - Powerstroke Nation
TANK'S 250 is offline
post #3 of 12 (permalink) Old 07-22-2010, 02:21 AM
Damnkids Motorsports
Mdub707's Avatar
Send a message via AIM to Mdub707
Those torque specs are no good if you use their new lube FYI.
I would just follow ARP's recommendations. JMO.
DamnKids Motorsports
2006 F-250 6.0 4x4 Vegistroked
SCT Xcal2 w/Innovative Diesel Tuning 466/772 7/19/08
Black smoke don't mean it's broke... it means your tuning sucks!
Originally Posted by CSIPSD View Post
Paypal can go fuk themselfs... Buy me a beer the next time we meet.
Mdub707 is offline
post #4 of 12 (permalink) Old 07-22-2010, 02:26 AM
justintimemoto's Avatar
x2 just do what they tell you if your not sure call arp
sucperchips flashpaq, banks ram air, 4"mbrp straight piped rcd egr delete leveled
justintimemoto is offline
post #5 of 12 (permalink) Old 07-22-2010, 02:26 AM
got fuel?
goodstktbo's Avatar
Buddy has his arp's to 280 ft lb
97 250/95 motor, 400/300's, ts, swamps tuning,gen3, s475, Intercooled, h11 studs,a1000, built tranny. 3.55's, 237,xxx miles fastest non reg. cab obs [email protected] fuel
94 explorer. dd
goodstktbo is offline
post #6 of 12 (permalink) Old 07-22-2010, 04:41 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Why?
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #7 of 12 (permalink) Old 07-22-2010, 02:27 PM
got fuel?
goodstktbo's Avatar
A shop does it that way. Need a big old tq wrench lol. working tho, got 200cc sticks and stuff.
94 explorer. dd
post #8 of 12 (permalink) Old 07-22-2010, 06:01 PM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
I'm pretty sure this was/is the details on the the current spec, New Preload (torque) Recommendations for 6.0 ARP studs - Powerstroke Nation
As for the 90į method I think that mostly came out of Beans shop with turbo99's truck and bit of discussion on it buried here in this thread, How many have had multiple blown HG's? - Powerstroke Nation
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #9 of 12 (permalink) Old 07-23-2010, 05:09 PM
Follow the instructions that come with the studs, torque spec will vary depending on which lube is included in the kit.
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
post #10 of 12 (permalink) Old 07-25-2010, 07:36 PM
Mdub707's Avatar
I was actually contacted by someone from ARP and spent a little time talking with them on the phone about the subject.
ARP has made it clear that torquing the studs past their specs will in fact YIELD the stud.
280 ft/lbs is way too much.
They spent a lot of time engineering a new lube so that the torque readings would stay consistent even if they were torqued, loosened, then retorqued. The new lube also only requires a 210 ft/lb torque. Follow their instructions!
Mdub707 is offline
