gauges or headstuds - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 38 (permalink) Old 07-17-2010, 03:02 AM Thread Starter
justintimemoto's Avatar
gauges or headstuds
i finally bought a programmer for my truck, im looking into either getting gauges and doing headstuds eventually if they go bad. im looking at getting auto meter gauges and i was wondering should i go w four gauges or 3 also what ones should i get trans pyro boost fuel? i really dont want to go over 300 but i can if i have to. where is the cheapest place to get them if anyone knows? any information is appreciate thanks
sucperchips flashpaq, banks ram air, 4"mbrp straight piped rcd egr delete leveled
justintimemoto is offline
post #2 of 38 (permalink) Old 07-17-2010, 03:07 AM
SamW's Avatar
Re: gauges or headstuds
EGT, coolant temp and fuel pressure are a good place to start. oil temp is not bad either. FCDP is a vendor on here and has quick customer service. I would recommend them.
2006 F250 CCSB
6.
SamW is offline
post #3 of 38 (permalink) Old 07-17-2010, 03:36 AM
psn local
head studs first imo
smokin6.0psd is offline
post #4 of 38 (permalink) Old 07-17-2010, 04:19 AM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
I have 4, Pyro, Oil temp, Coolant temp and fuel pressure.
With xtreme race I can watch my fuel pressure drop right off when I floor it. And the oil/coolant gauges are good to get an early warning on your oil cooler plugging up.
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #5 of 38 (permalink) Old 07-17-2010, 05:03 AM
06-sixoh's Avatar
I would do gauges first. this will help you monitor your powerstroke, to prolong the need for studs. You can go get studs done, run the piss out of your truck, and have to do it again. At least with gauges, you will have a better idea of when your truck is crying.
Gauges, I would go Fuel, EGT and Trans OR coolant temp. 300 is going to be a tight budget, Im going through the same thing right now. If you can afford it, try to get the Edge Insight CS w/ EGT Probe. This will run you around $400 from innovative. This doubles as a diagnostics tool also. But if you set on gauges, I think ISSPRO, or Autometer is going to be your best bet. I am probably going to go the cheaper route, and get the GlowShift gauges, tinted 7 color option. They put together a package. Im getting the EGT, fuel and trans, with grey pillar pod for $200. Reviews show the gauges to be accurate, but many dont like them. Im on a budget, so Im going this route for now, unless I can find a cheap Insight with probe...
Good luck...
2006 F250 CCSB FX4 Lariat
GlowShift Tinted gauges, Recon Clear Cab Lights, Diamond Eye Duals, SRL Files, 2.5" rize leveling kit, F350 Rear Blocks, PHP Tuned FICM, Retro Solution 6K HID's, DieselSite Coolant Filter...
2011 Oxford White SuperCrew EcoBoost FX2
06-sixoh is offline
post #6 of 38 (permalink) Old 07-17-2010, 11:21 AM Thread Starter
06-sixoh i was on your post to w the glow shift gauges i like the kit it comes w. but i dont understand why many dont like them can someone explain to me why many dont like them?
post #7 of 38 (permalink) Old 07-17-2010, 12:21 PM Thread Starter
i also pull trailers quite often if that matters
post #8 of 38 (permalink) Old 07-17-2010, 12:25 PM
SamW's Avatar
you still have warranty left?
2006 F250 CCSB
6.
SamW is offline
post #9 of 38 (permalink) Old 07-17-2010, 12:36 PM Thread Starter
yeah
post #10 of 38 (permalink) Old 07-17-2010, 12:55 PM
Proud Sponsor
Abrannan19's Avatar
I would suggest and Edge insight for gauges...they work very well, its very accurate and offers alot for the money, plus a simple install to boot. Soon Edge will have accessory senders available for the new Insight CS/CTS so that we can install them wherever and have things like fuel pressure and oil pressure off on unit, that's what's makes these units killer.
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
