175's or 190's...what would you do? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 62 (permalink) Old 07-16-2010, 02:30 AM Thread Starter
BRING DA AMBALAMPS
stroke of luck's Avatar
I bought some Casserly 190's off of Countryboy07 on here (thanks Josh!) and we're sending them to Cass to go through before they come to me. Question is...should I leave them as 190's or dial em back to 175's. the truck is a daily driver and will make occasional passes down the track. I want a fun truck on the street that will make some good numbers (shooting for 500). I'll have the stock turbo for a few months until I go to a bigger VGT. Whattya think?
2005 CC FX4...compounds and everything else that goes with em.
stroke of luck is offline
post #2 of 62 (permalink) Old 07-16-2010, 02:35 AM
Hater Club
Dirk's Avatar
Re: 175's or 190's...what would you do?
A good set of 155's, proper turbo, and a good tune...
Will destroy a 5r110.
Just my .02, but like I said on the phone the other day, use caution. Unless you're out to break $hit like me.
Porch Monkey. It's cool, I'm taking it back.
Dirk is offline
post #3 of 62 (permalink) Old 07-16-2010, 02:43 AM
amos moses
strokeit06's Avatar
my personal advice would be. go big or go home! if you dial back to 175's your gonna want 190's! i know whenever i build something i always end up doing it again to go bigger!
arp's,black onyx gaskets,fcdp egr delete,fcdp coolant filteration,cfm largemouth,innovative tuned,7"stacks,35" toyo mt's,glowshift gauges, and some recon lights
strokeit06 is offline
post #4 of 62 (permalink) Old 07-16-2010, 02:44 AM Thread Starter
BRING DA AMBALAMPS
Just my .02, but like I said on the phone the other day, use caution. Unless you're out to break like me.
I thought the 5r110's were pretty stout if tuned properly? I'm usually pretty easy on the truck. just the occasional wot run up the onramp or something. I'll be taking it to the track some too. I just like to know the power is there if I need it.
post #5 of 62 (permalink) Old 07-16-2010, 02:45 AM Thread Starter
BRING DA AMBALAMPS
that's kind of what i'm thinking...
post #6 of 62 (permalink) Old 07-16-2010, 02:45 AM
it's an 02 05 08
turbodiesel_02's Avatar
i would go with 190's but sooner or later you'll need a trans
2002 ext. cab lwb 4x4 7.3
05 front 08 rear conversion
4in lift,forged rod motor,tunes by tsd,bts trans,6.0 transcooler,6 autometers to watch,studs,springs,push rods,238cc hybrids,itp reg return,stealth hpop,tsd custom fuel system and sump,an so on
6.0's pay the bills and 6.4's soon..
turbodiesel_02 is offline
post #7 of 62 (permalink) Old 07-16-2010, 02:50 AM
Hater Club
Dirk's Avatar
I tell you what, leave the truck the way it is...
Drop your truck off at my house or MrJohnWayne's house.
Then have a wrecker come by after 24hrs.
Dirk is offline
post #8 of 62 (permalink) Old 07-16-2010, 02:51 AM
SamW's Avatar
190s are good. the 5r will hold fine with those injectors. A built transmission can fail too. its all in the tuning and drivers foot.
2006 F250 CCSB
6.
SamW is offline
post #9 of 62 (permalink) Old 07-16-2010, 02:55 AM
psn local
you can make 475-500 with 175cc with a few upgrades like adding a hpop a good turbo like a garrett powermax ,fuel rr and pump,and eric's extreme race can put you around there. for sure 190cc can get you there. but the 175 are a tad bit better for dd and towing. ask rescue250 he dynoed at 500 with 190cc. shawn built a twin turbo set up for a guy running 190cc he said around 600 with a extreme tune and 500-525 witha tow tune
smokin6.0psd is offline
post #10 of 62 (permalink) Old 07-16-2010, 02:56 AM
All done now
Arisley's Avatar
As much as I wanna say go with the 190's. Dirk is right more often than not. So only go 190's if you have more room on the credit card.
Arisley is offline
