dually tires - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 02-14-2008, 11:24 AM Thread Starter
dually tires
I would like to put 295/70 17" tire on my stock wheels (6.5" wide). I know I will need a spacer. I also know the manufacturer recomends 8" wide wheels.
I have read about others doing what I want to do and would like to know this.
How has it worked out? Any problems? Any pictures of this set-up?
Thanks for any help you may have answering these questions.
jdr01 is offline
post #2 of 5 (permalink) Old 02-14-2008, 04:24 PM
Slated4Greatness's Avatar
Re: dually tires
If you use it for towing heavy or loading the bed I would not recommend it. There is a reason there are required wheel widths..
2006 F350 Lariat Tow Boss W/training wheels.
SCT W/GH's tunes, ARP's, Blk & Heads milled, Strictly RR and aux coolant lines, 6" Aussies, Snow MPG-Max, BPD: VK688,EGR, W/Pump, and FICM, Coolant filt, Train Horns, CTS (Monitor only) + Autometer backups
RIP Muley 9-25-09
Keep on Honkin' Jerry 04-05-10
Slated4Greatness is offline
post #3 of 5 (permalink) Old 02-15-2008, 01:11 AM Thread Starter
Re: dually tires
I know but I can't find what I really want. I would like to take the dually adapter off the front change the wheel to hold the bigger tire. On the rear I would like to have the correct width tire for the stock rim with the same diameter as the front.
jdr01 is offline
post #4 of 5 (permalink) Old 02-15-2008, 01:17 AM
Re: dually tires
I run 305/70/17 Nitto terra Grapplers with a 2" spacer and havent had any problems yet. I've had 5-6k lb of tongue weight off road with my gooseneck and it's holding up fine.
Rprops is offline
post #5 of 5 (permalink) Old 02-19-2008, 01:00 PM Thread Starter
Re: dually tires
That looks good. Thats probably the direction I will head with my truck.
Thanks
jdr01 is offline
