TPS Nitrous Activation Switch - Which Factory Wire? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 02-06-2008, 08:12 PM Thread Starter
Diesel Addict
BilletGarage's Avatar
I could test every wire on the factory TPS switch but I was wondering if anyone knew which wire to tap into for a Nitrous TPS switch? Basically the one that gives you the 0-5V spread. Thanks in advance!
BilletGarage is offline
post #2 of 6 (permalink) Old 02-06-2008, 08:38 PM
Re: TPS Nitrous Activation Switch - Which Factory Wire?
There is supposed to be a seperate instruction sheet with the TPS on a ZEX kit to tell you which wire to use depending on vehicle.
xtremexj is offline
post #3 of 6 (permalink) Old 02-06-2008, 08:38 PM
Sponsor
Logan21SV's Avatar
blue with black tracer
CenTexDiesel.com
Logan Schneider
830-885-6500
Logan21SV is offline
post #4 of 6 (permalink) Old 02-06-2008, 08:56 PM Thread Starter
Diesel Addict
Unfortunately I am not using a ZEX TPS . . . Maybe I will check the instructions online at ZEX though. Thanks.
post #5 of 6 (permalink) Old 02-06-2008, 08:57 PM Thread Starter
Diesel Addict
Perfect! Thank you!
post #6 of 6 (permalink) Old 02-10-2008, 04:30 AM Thread Starter
Diesel Addict
Just so it is not confusing for anyone, On the 2003 and 2004 6.0L Trucks the TPS wire needed for the falling voltage signal near the throttle is Light Blue with a black tracer. On the 2005 - 2007 the wire is the Yellow with White Tracer. I forgot to clarify I had a 2005 when I posted this thread. Sorry . . .
