Aftermarket headgaskets? - Page 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #11 of 16 (permalink) Old 02-09-2008, 01:33 AM Thread Starter
Broke's Avatar
Re: Aftermarket headgaskets?
The reason that i don't like the factory design is because I don't feel that the blue sealing surface is large enough. I have heard,and I will admit this is by hearsay that any minor imperfection in the head or block will not let the gaskets seal properly.As far as a stock truck is concerned i haven't ever seen a repeat failure.But I did have on that had tuning,injectors,and studs blow the headgaskets again after around 6,000 to 8,000 miles later.(Again this is just my personal opinion)
96 F-350 CC 4x4 (Truck on hold due to move
Shackle extentions, SD turbo
35" BFG"S, fuel system
Mild Trans work, 01 HPOP
Chip,Guages,Exhaust
Broke is offline
post #12 of 16 (permalink) Old 02-09-2008, 02:35 AM
FordF250Stroker's Avatar
Did u check the heads and deck for warpage?
1997 F250,5 speed handshaker, Afe Stage 2 intake, 6 inch miter stacks, Di 4 position chip, FASS 150/180, Regulated Return and Fuel Bowl Delete,Guages, 4in" Superlift 35 Toyo Open Country M/T
Cen - Tex Diesel Performance
Logan Schneider
FordF250Stroker is offline
post #13 of 16 (permalink) Old 02-09-2008, 05:03 AM
IGotIt's Avatar
I have seen alot of the heads that are poor machining from the factory. I have seen them so rough it was horrible and they were six thousanths out of flat. That will never let an MLS seal up. I own four sets of heads and they were all far from flat. I have one set that is so cracked out also, between all valves and to all glow olug holes.
Thank You: John Wood Automotive, CS Diesel Performance,Terminator Engineering, Black Widow Diesel, Hulinski Tire & Lube.
IGotIt is offline
post #14 of 16 (permalink) Old 02-11-2008, 07:13 PM
Quit drinking those heads are flat!!!
Logan21SV is offline
post #15 of 16 (permalink) Old 02-11-2008, 10:05 PM Thread Starter
Broke's Avatar
Yea, checked them both times I had the heads off.They were ok
Chip,Guages,Exhaust
Broke is offline
post #16 of 16 (permalink) Old 04-01-2008, 09:24 AM
some one post pics of the stock hg's to the hypermax hg's
SuperStroker10 is offline
