2.6 sledpuller turbo? Precision Turbo? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 52 (permalink) Old 04-19-2010, 10:29 PM Thread Starter
Sponsor
jwarren's Avatar
Precision PT67 What you think about this turbo? What exhaust A/R should I go with I won't be running a waist gate. I am going with 225CC injectors.
Precision PT6765H T67 PT67 Turbo NEW T4 Garrett GT35R : eBay Motors (item 110435931032 end time May-15-10 08:33:56 PDT)
I'll run this Turbonetics 6.0L Turbo Pedestal Kit from dfuser.
http://www.dfuser.com/img/turbonetic...destal-Kit.jpg
jwarren is offline
post #2 of 52 (permalink) Old 04-20-2010, 01:20 AM
Redneck6.0L's Avatar
Re: 2.6 sledpuller turbo? Precision Turbo?
elite uses garret turbo's, you might want to consult with them,
2006 F-350 crew cab dually 4X4
225cc injectors, CRD twin turbo's
Fueled by Gibson's
2003 F-350 crew cab
[email protected]
Redneck6.0L is offline
post #3 of 52 (permalink) Old 04-20-2010, 02:18 AM Thread Starter
Sponsor
jwarren's Avatar
I can't find any on there web sight might need to give them a ring.
Wonder would a .96 A/R be to big?
jwarren is offline
post #4 of 52 (permalink) Old 04-20-2010, 04:28 AM
get a pedistal to mount a S400 and get a S465. If you want to be competitive run what the big boys are running
halerazor is offline
post #5 of 52 (permalink) Old 04-20-2010, 11:53 AM
Brentos's Avatar
unless you have a six speed or a high stall converter you wont be spooling a s400 with any ease at all.
Brentos is offline
post #6 of 52 (permalink) Old 04-20-2010, 01:25 PM Thread Starter
Sponsor
jwarren's Avatar
I am going with that Precision Turbo there I just want an idea of what exhaust a/r to go with I won't run a wastegate.
jwarren is offline
post #7 of 52 (permalink) Old 04-20-2010, 01:57 PM
But if you don't have a s400 your not touching the top 5. the 2.6 class is now in between 700-900hp here in ohio
post #8 of 52 (permalink) Old 04-20-2010, 02:10 PM
lubeowner's Avatar
What are your class rules? If they allow stepped covers then you will not stand a chance with that turbo. Guys will have a Precision built 3.0 wheel cut and stuffed into a 2.6 cover and will move way more air. You will need a $4000 custom built turbo to compete. And the "big guys" are not running s465's they are running S480 with 2.6 covers. Like this.
Jeremy Johnson
Search "lubeowner" on youtube for many truck pulling videos.
dieseldr.net
We build Powerstroke pulling trucks.
lubeowner is offline
post #9 of 52 (permalink) Old 04-20-2010, 02:32 PM
How things change in only a year they were runnin s465's last year, is that s480 a bushed housing? if so it's no good in ohio. When i pulled 4 years ago in the 2.5 class i dominated the class with a 62mm s300. Then it went to 2.6 and the guys were winning with 66mm s300's now you don't stand a chance unless your running a s400. A street driven truck can no longer compete in the street class.
post #10 of 52 (permalink) Old 04-20-2010, 02:39 PM
lubeowner's Avatar
That is not a bushing. That is a 80mm wheel with the ends clipped and protrudes into a 2.6" cover. The wheel is 2.6" measured at the smallest diameter of the compressor wheel. But after the 1/8" as most rules state the wheel steps out to the 80 mm and the big part of the wheel grabs air through the 1/4" map width enhancement groove.
Jeremy Johnson
dieseldr.net
