Aftermarket Injector MPG ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 30 (permalink) Old 04-19-2010, 10:18 PM Thread Starter
dstryr's Avatar
Looking for you guys to post up your new mpg (hand-calculated) with whatever size injector you are running?
I was reading on here that one company's (forgot which) 155's increased 3 mpg over stock?
Looking to buy some up very soon and want to find the fine line between power and mileage.
dstryr is offline
post #2 of 30 (permalink) Old 04-20-2010, 06:22 AM
Re: Aftermarket Injector MPG ?
Elite, with their 8-hole nozzles vs. stock 6-hole.
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
post #3 of 30 (permalink) Old 04-20-2010, 11:47 PM
doofpowerstroke's Avatar
what size of injecters u running
doofpowerstroke is offline
post #4 of 30 (permalink) Old 04-20-2010, 11:48 PM
I'm running stock, I've just read about Elite's injectors recently.
post #5 of 30 (permalink) Old 04-22-2010, 12:18 AM
SamW's Avatar
you will see improved mileage with any mild injector upgrade. all depends how much you can keep your foot out of it.
2006 F250 CCSB
6.
SamW is offline
post #6 of 30 (permalink) Old 04-22-2010, 03:41 AM Thread Starter
dstryr's Avatar
Anyone have any numbers? I'm not looking for huge power upgrade but thinking about doing just injectors if there is a decent mpg and power gain....thinking like 155's ?
dstryr is offline
post #7 of 30 (permalink) Old 04-22-2010, 04:28 AM
SamW's Avatar
155s are good, dont go bigger then 190 for a daily driver but if you run bigger injectors make sure you have a motor that can take it. studs custom tunes and an egr delete along eith the other basic mods are nessisary first. I had 190s, might go with 155s and a stock turbo next. with 155s you can run a modded vgt or 62/70 or stay with a stock turbo and have a solid dd that will still get up and go.
2006 F250 CCSB
6.
SamW is offline
post #8 of 30 (permalink) Old 04-22-2010, 06:53 PM Thread Starter
dstryr's Avatar
Already have Custom SCT tunes
Getting studs and EGR delete within the next few months. FIgured while it was apart might as well...gotta stay somewhat mild on injectors due to california smog tests now.
I've heard you can make 500hp with 155's and stock turbo? I think with SCT its 410hp? so 90 hp and 3mpg increase is good in my book.
dstryr is offline
post #9 of 30 (permalink) Old 04-22-2010, 10:47 PM
yosh30's Avatar
if you go with the 155's you will need a fuel system. I'm doing the AD2 when I do my injectors so I won't be croosing my fingers hoping my stock pump will hold up. Plus it's always nice to know that your injectors are getting plenty of fuel
2003 FORD F350 6.0
6" Fabtech Lift
37" FCII on 17" weld racing wheels
SCT X3 soon w/ custom tunes
Banks Ram Air Intake
Banks High Ram Intake
MBRP 5" Exhaust w/ 7 inch tip
Snow Performance Stage 3 w/ custom 11 gallon tank
Custom SpeedHut Gauges
F650 Dash Mod
Zoodad Mod
Bed w/Blue Water LED's
Bedrug
yosh30 is offline
post #10 of 30 (permalink) Old 04-22-2010, 11:06 PM
The stock pump can handle 155s, but I would have a fuel gauge to make sure. I would also upgrade the banjo bolts to remove that restriction.
