Reuse ARP's???? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 04-17-2010, 05:18 AM Thread Starter
WINNING
Countryboy07's Avatar
Exclamation Reuse ARP's????
Before someone says it, I know there are threads about this already, but I have specific question. So here goes, I am getting ready to pull the cab for the second time to do the gaskets. Well the first time they were done, the mechanic torqued the studs to 260 ft. lbs. My question is, would it be safe to reuse the studs in my case and only torque them to the 250 ft. lbs. that ARP reccomends? Thank you for the help.
-French
2002 VW Jetta TDI
Countryboy07 is offline
post #2 of 21 (permalink) Old 04-17-2010, 05:28 AM
I Just Break Stuff
Re: Reuse ARP's????
Best I can remember. ARPs are torqued to 245. I believe they can be used 5 times. Seeings how they where torqued to 260, you may want to call ARP and see. Maybe someone else will chime in that knows a little more about it. I've never heard of the effects of torquing them past spec. Don't know if it would hurt them or not. I'm not an engineer, but I'm sure there's a formula as long as my leg to figure it out.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
post #3 of 21 (permalink) Old 04-17-2010, 05:38 AM
your mom
RMPowerstroke's Avatar
Re: Reuse ARP's????
it shouldnt hurt but do you know why the gaskets went heads warped? hows the deck of the block. I'm runing arp and there tq to 280 cuz your not the first to blow gaskets with arps. i dono exactly but some one told me i was better off with them at 280 just becafull not to brake them.
f350 king ranch dubed. ol ranchero thanks to wayne
04 cc/lb 9inch lift C-6 built converter custom revs manual valve body r servo. powered by 12v cummins p-pump 4k gvs custom lasered dlv pump work, 5x16 sticks, singler charger for now, airdog150, its on meth lots of custom junk. hids road armor bumper and im truck broke
06 f-150
RMPowerstroke is offline
post #4 of 21 (permalink) Old 04-17-2010, 05:38 AM
Hater Club
Dirk's Avatar
Re: Reuse ARP's????
Call ARP and get the maximum length on the stud. After install and use, they will stretch a bit. If they are in tolerance, use them. I've heard people say that they don't stretch... bull####.
Get a micrometer and take a look.
Porch Monkey. It's cool, I'm taking it back.
Dirk is offline
post #5 of 21 (permalink) Old 04-17-2010, 05:49 AM Thread Starter
WINNING
Re: Reuse ARP's????
I am actually suspecting a cracked head to be the culprit, but I'm not 100% sure either way. It will only leak when the engine is cold, but once everything heats up, it doesn't leak again until it has sat for a few hours. I have already bought different heads and have new gaskets sitting in my garage, so they are getting changed one way or another.
-French
2002 VW Jetta TDI
post #6 of 21 (permalink) Old 04-17-2010, 06:02 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Re: Reuse ARP's????
There should be a length that states the fatigued state.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #7 of 21 (permalink) Old 04-17-2010, 06:03 AM
Hater Club
Dirk's Avatar
Re: Reuse ARP's????
Exactly.
Dirk is offline
post #8 of 21 (permalink) Old 04-17-2010, 06:05 AM
CanadianRedneck's Avatar
Re: Reuse ARP's????
I've seen ARP's reused many times and only ever seen one break I think. I wouldn't think twice about reusing yours. Just use lots of lube when you're retorquing them
2005 F350 Crewcab 4x4 6.0L
64mm turbo, NADP race tranny, tuning by Eric at Innovative Diesel
2004 F250 4x4 6.0L
Work in progress.......
EDE heads, cam, pistons, hybrid injectors, Hypermax rods,
2 really big turbos and a whole bunch of other crap to come.....
Tuning by Innovative of course!
CanadianRedneck is offline
post #9 of 21 (permalink) Old 04-17-2010, 06:45 AM Thread Starter
WINNING
Re: Reuse ARP's????
Do you know what this length is by chance?
What lube would you reccomend? ARP's or another brand?
-French
2002 VW Jetta TDI
post #10 of 21 (permalink) Old 04-17-2010, 06:58 AM
Hater Club
Dirk's Avatar
Re: Reuse ARP's????
-French
Like I said, call ARP to verify the length and then mic it out. Better to get the info straight from the source.
I've mic'd my 7.3 ARP's that where used twice by me and they were in damn near brand new shape.
The H11's I just sold, were the same way.
I've used the ARP lube on H11's and ARP's. Just remember, don't YANK the torque wrench. Gently pull to the desired setting. More studs have been broken by incorrect installation than anything else.
Dirk is offline
