White smoke no EGR ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 04-13-2010, 11:13 AM Thread Starter
Mike Hickman's Avatar
My o6 has started smoking white, egr deleted
H11's in and sound engine. What could cause white smoke ? I let the the truck warm up but on take off it smokes and after 2 miles I get it on take off again but do not see it after that ? I'm running no tune and it still has some smoke ?
2006 Lariat FX4 F-350 7" BDS Lift
SCT Xcal3 Tuned By Chris B @ Truck Source Diesel TSD !
Triple pod Auto Meters
4" MBRP Exhaust
A1 H11 Studs Head Bolts
EGR Deleted
Mike Hickman is offline
post #2 of 15 (permalink) Old 04-13-2010, 11:29 AM
Re: White smoke no EGR ?
The head gasket could be goin out. Have you been using an coolant?
ericrider07 is offline
post #3 of 15 (permalink) Old 04-13-2010, 11:31 AM Thread Starter
zero coolant ...
4" MBRP Exhaust
EGR Deleted
post #4 of 15 (permalink) Old 04-13-2010, 11:33 AM
What does the smoke smell like?
post #5 of 15 (permalink) Old 04-13-2010, 11:34 AM Thread Starter
I have been the only driver while taking off not sure off hand . I run stanadyne in the fuel 24/7 ,
I'm thinking unburnt fuel / warming up ?
4" MBRP Exhaust
EGR Deleted
post #6 of 15 (permalink) Old 04-13-2010, 11:57 AM
Proud Sponsor
Abrannan19's Avatar
some white smoke is normal with the cat removed. Does it do this with the tuner removed?
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #7 of 15 (permalink) Old 04-13-2010, 04:40 PM
Turbo seals could be shot. Just got mine back after a brand new center section.
Mine would smoke on start-up and from a stop. The longer I sat idle at a light, the more white smoke I would get on take-off...once the turbo was completely up to operating temps I didn't see much smoke. Dealer told me that is because the housing is hot enough to burn the oil off as it leaks past the seals so you don't notice it. When it is cold, it will pool until you take off from a stop and get the EGT's hot enough to burn the oil.
FaSSt9602 is offline
post #8 of 15 (permalink) Old 04-13-2010, 09:55 PM Thread Starter
FaSSt9602
This is exactly what mine does ... Thanks
Abrannan19
I removed the tune and running stock just to see if smoke is there . Yelp still there.
4" MBRP Exhaust
EGR Deleted
post #9 of 15 (permalink) Old 04-13-2010, 09:59 PM
Banned
there is a bulletin (recall) on the supply or drain line to / from the turbo .
Thats what caused my white discharge from stop top stop.
$100. deduct.
FRUITBOY is offline
post #10 of 15 (permalink) Old 04-14-2010, 12:49 AM
It wasn't me
offroadinginaz's Avatar
Does it seam "boggy" when it smokes? Mine did and the dealer replaced 2 injectors which solved the problem
Newman
A few Fords
Special Thanks to:
offroadinginaz is offline
