6.0 Injectors Aftermarket - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 04-12-2010, 05:42 PM Thread Starter
doofpowerstroke's Avatar
hey if anyone would help me i am looking to build my 2006 powerstroke up and i have got everything found but an aftermarket injection pump and injectors if some one would wanna help me out on some of this stuff.
doofpowerstroke is offline
post #2 of 19 (permalink) Old 04-12-2010, 05:55 PM
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
Re: 6.0 Injectors Aftermarket
Airdog for pump wise, try ryan at full force diesel
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
post #3 of 19 (permalink) Old 04-12-2010, 05:59 PM
STROKER6.04LIFE's Avatar
What do u want out of your truck more info would help u out like what size turbu u have? Yre u looking to build the motor from the ground up or just bolt on parts??????? What size injectors do u want or are u Looking for help on what size to get???
Josh.
2003 6.0 RCLB
powermax
190cc
tuned by Eric and Matt
STROKER6.04LIFE is offline
post #4 of 19 (permalink) Old 04-12-2010, 08:03 PM
motoxracer42's Avatar
there is no injection pump on these trucks. thats why you cant find it. like said above most likely need a lift pump. sizing all depends on what you want to do with the truck.
06 crew cab
06 reg cab
motoxracer42 is offline
post #5 of 19 (permalink) Old 04-12-2010, 11:40 PM Thread Starter
o ok guys so where should i order some injectors from
post #6 of 19 (permalink) Old 04-12-2010, 11:41 PM
Haters Gonna Hate
Fordfreak4life's Avatar
elite diesel engineering! they get my vote anywho, when that time comes for me ill be going to elite for sure
Fordfreak4life is offline
post #7 of 19 (permalink) Old 04-12-2010, 11:43 PM Thread Starter
i am looking at an Aurora 5000 on it but i need some info becasue i dont know if thats too much i have the truck head studded and i have a hybred turbo that use to make like 40 psi and now i am lucky if i can make 28 so idk what the deal is i have afe intake stage 2 and a superchip flash pack and 5 inch exhust. i want the truck to run about 600 hp and i want some big injectors
post #8 of 19 (permalink) Old 04-12-2010, 11:51 PM
SamW's Avatar
your gonna need a custom tuned sct to make any turbo run right, not just a superchips. dont go bigger than 190 cc for injectors and 64 mm for the turbo if you want to have a reliable daily driver that is very streetable. make sure you have an egr delete too... Not alot of people run aurora turbos either. might look at industrial, elite or elsewhere. you will lose alot of your daily driveability once you go to a big non vgt.
2006 F250 CCSB
6.
SamW is offline
post #9 of 19 (permalink) Old 04-12-2010, 11:52 PM
Haters Gonna Hate
well to start with ditch ur *flashpack* and get an sct programmer, then check your boots on you ic piping and make sure its not leakin, if no leaks there try checkin the up pipes to the turbo
post #10 of 19 (permalink) Old 04-13-2010, 05:19 AM Thread Starter
so super chips are junk or what and ya the blades in the turbo are bent to #### so i thinks its time for a new bigger one and y not go with 255 cc injectors
