SCT tunes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 01-23-2008, 05:17 AM Thread Starter
HarleyEdition78412's Avatar
Question SCT tunes
What tunes is everyone running? I bought a Livewire w/extreme tune from Eric over at Innovative. I figured I'd get extreme street but not sure about the final 2. Anyone have any recommendations for someone that doesn't tow? When I had my 7.3L my DD was the 100hp performance on my DP F16 chip.
Current- 2006 Harley Davidson Edition F250 6.0L w/a "BUILT" engine, Unfortunately mis-assembled and installed by CenTex Diesel and a NAPD Heavy Hauler RACE SERIES Transmission
Previous- 2001 Platinum Edition F250 7.3L
SCT LW and FICM tuning-
Regulated Return fuel kits-
ENOUGH SAID
HarleyEdition78412 is offline
post #2 of 15 (permalink) Old 01-23-2008, 05:26 AM
Sponsor
Logan21SV's Avatar
Re: SCT tunes
never ran any of Erics tunes but ive heard they are good. hopefully someone that has ran some of his tunes will chime in.
CenTexDiesel.com
Logan Schneider
830-885-6500
Logan21SV is offline
post #3 of 15 (permalink) Old 01-23-2008, 11:56 AM
Adrenalin Junkie
Re: SCT tunes
I run Eric's and DJ's tunes. Extreme Race in Innovatives and Looney in DJ's. They are pretty closer. I get an average of .04 faster with DJ's tune.
PSD Trav is offline
post #4 of 15 (permalink) Old 01-23-2008, 03:18 PM
Slated4Greatness's Avatar
Re: SCT tunes
Be careful running extremes without head studs..
2006 F350 Lariat Tow Boss W/training wheels.
SCT W/GH's tunes, ARP's, Blk & Heads milled, Strictly RR and aux coolant lines, 6" Aussies, Snow MPG-Max, BPD: VK688,EGR, W/Pump, and FICM, Coolant filt, Train Horns, CTS (Monitor only) + Autometer backups
RIP Muley 9-25-09
Keep on Honkin' Jerry 04-05-10
Slated4Greatness is offline
post #5 of 15 (permalink) Old 01-23-2008, 03:37 PM
lott is my daddy
mxchase's Avatar
Re: SCT tunes
i ran DJs stuff for a few months and around the same time i did my lift and tires i started to run Eric's. my truck finally blew the gaskets but i was expecting it.
i would also try from Eric, his economy tune, and his highway economy...difference is the highway one makes more power when you roll on it from 70. those are what i have from him. from DJ i have pretty much the same thing except his looney and also a smoke tune.
i always run on looney or extreme. if you dont abuse it you will get as good as milage, always have the abilitly to kick some ricers ass, and always be able to smoke some unsuspecting tail gater.
i'd rather be hated by 12 than carried by 6
mxchase is offline
post #6 of 15 (permalink) Old 01-23-2008, 03:41 PM
lott is my daddy
mxchase's Avatar
Re: SCT tunes
also if you dont have a turbo back system i recommend getting one before you run your truck hard. it will greatly help reduce your egts.
and i dont know what your local stealership is like that you will get warrenty work done at but if you can run catless it sounds badass on these trucks
mxchase is offline
post #7 of 15 (permalink) Old 01-23-2008, 08:59 PM
kingranch1's Avatar
Re: SCT tunes
Hello, I am new to the site and I have been talking w/Innov about a SCT Livewire aswell. Please let me know your outcome as I will probably order mine the week after next. Thanks Richie
kingranch1 is offline
post #8 of 15 (permalink) Old 01-24-2008, 12:12 AM
Adrenalin Junkie
Re: SCT tunes
I don't think that livewire is all its cracked up to be.
PSD Trav is offline
post #9 of 15 (permalink) Old 01-24-2008, 12:51 AM
lott is my daddy
mxchase's Avatar
Re: SCT tunes
livewire is a little more then the xcal 2...its about $200 more. you get a lot more out of it. it does double as gauges and if you buy an egt probe you can monitor most of what you need to, (i usually do boost, coolant temp, engine temp, rpm, speed, and intake air temp) i dont have my egt cable yet but when i do i will take speed away and replace w/ egt. you can monitor 16 different things but up to 6 at once..and anything that you would have to "tap" into like trans or whatever else such as fuel or oil presure you would need gauges for.
im still getting 3 on my pilar but atleast i can have the other 6 at the same time
mxchase is offline
post #10 of 15 (permalink) Old 01-24-2008, 09:30 AM Thread Starter
Re: SCT tunes
Thanks for the responses, I went ahead and just got the Extreme street, street, and aggressive tow. I'll get to find out today how they work
