6.0L Coolant Circulation Line Kit - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 04-06-2010, 06:27 PM Thread Starter
WINNING
Countryboy07's Avatar
I know a few people have used this kit, but haven't really heard any feedback from those that have it. Is this a worth while mod to do while the heads are off? If it works like it is supposed to, I think it would be. Just looking for some feedback. Thank you
www.elitedieselengineering.com - 6.0L Coolant Circulation Line Kit
-French
2002 VW Jetta TDI
Countryboy07 is offline
post #2 of 11 (permalink) Old 04-06-2010, 06:54 PM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Re: 6.0L Coolant Circulation Line Kit
Take a look at your gasket. Look at the little holes in the middle cylinders for coolant to flow from block to head. Look at the big holes in the end. Coolant is supposed to flow up from the block to the head and then forward to the front cover. Which gives you dwell time for heat absorption. Since the majority of the issues is in the center cylinders. Giving coolant the chance to leave the back of the head and not have to go through the centers seems wrong to me.
Look at a 6.4L gasket. The holes to the center cylinders are bigger. Looks like that would improve coolant flow to the center cylinders.
Just my observation.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #3 of 11 (permalink) Old 04-06-2010, 07:02 PM Thread Starter
WINNING
Thank you for your observation. That is what I am looking for, someone that works on these engines daily. Anybody else want to weigh in?
-French
2002 VW Jetta TDI
post #4 of 11 (permalink) Old 04-07-2010, 08:04 PM
Extended Power's Avatar
I have had coolant recirc lines on my engine for almost two years...when I pull the heads, I will take pictures of it.
If I put them back on, I think I would run a valve on both sides, so I could shut them off in the winter time.
2003 F-350 KingRanch 4x4
Extended Power is offline
post #5 of 11 (permalink) Old 04-07-2010, 08:59 PM Thread Starter
WINNING
Yeah, I can remember you saying somthing about the lack of heat in the winter time. Did you narrow it down to the lines causing the problem?
-French
2002 VW Jetta TDI
post #6 of 11 (permalink) Old 04-07-2010, 10:28 PM
I think it was the -40*C/-40*F weather...
I also have the small water pump...but not for long.
post #7 of 11 (permalink) Old 04-07-2010, 11:13 PM
6.0 money pit
smokinstroker's Avatar
where are you getting your bigger water pump? i have been looking for one..
smokinstroker is offline
post #8 of 11 (permalink) Old 04-08-2010, 12:47 AM
Captain Negativity!
PSDPlayer's Avatar
He is just getting the pump everyone got in 04.
Email:
post #9 of 11 (permalink) Old 04-08-2010, 01:45 AM
Exactly!!
post #10 of 11 (permalink) Old 04-08-2010, 02:43 AM
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
Im doing the same
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
