Fuel pressure spring - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 04-05-2010, 11:35 PM Thread Starter
Advantages? Disadvantages? Whadya' think?
GDS Fuel Spring
'04 F350 CCLB DRW. With some stuff.
Redwood 36FL
spindrift is offline
post #2 of 21 (permalink) Old 04-06-2010, 01:56 AM
Sponsor
jwarren's Avatar
Re: Fuel pressure spring
Drill your banjos out and add this spring, you won't go threw injectors after these mods.
jwarren is offline
post #3 of 21 (permalink) Old 04-06-2010, 04:31 AM
100psi is to much fuel pressure it will cause the injectors not to operate correctly
halerazor is offline
post #4 of 21 (permalink) Old 04-06-2010, 12:30 PM
Sponsor
jwarren's Avatar
The spring I use is a 60 psi spring
jwarren is offline
post #5 of 21 (permalink) Old 04-06-2010, 03:50 PM
ford03six0's Avatar
Where did you get the 60 psi spring? I just installed a fuel pressure gauge and at idle it sits at 54 psi and at fuel pedal on innovatives street tune it drops to almost 42 psi.
2003 6.0
Innovative cutom tunes
Innovative FICM
egr delete
headstuds
k/n intake
Garret Stage 1
Banks IC
Ceramic coated exhaust manifolds and Y pipe
4 inch lift on 35 Toyo mud terrains
4" straight pipe
Triple pod Autometer gauges Ultra liteII boost,egt,and fuel pressure
BTS Billet transmission
more to come........
ford03six0 is offline
post #6 of 21 (permalink) Old 04-06-2010, 05:20 PM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Just stretch the stock spring if you want more pressure.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #7 of 21 (permalink) Old 04-06-2010, 06:09 PM
ford03six0's Avatar
Are you being serious? what is good fuel pressure and what is bad?
2003 6.0
Innovative FICM
egr delete
headstuds
k/n intake
Garret Stage 1
Banks IC
4" straight pipe
post #8 of 21 (permalink) Old 04-06-2010, 06:14 PM
<-MONEY PITT!!
ifitssmokinitsstrokin's Avatar
Yes he is serious...I did it to my spring before the full fuel system and the air dog II
2010 CCSB Afe Intake and dual exhaust
2006 CCLB F-250 Studs,Squeez,EGR delete,RR to AirDog II and a Airraid Intake & Sct Hot tunes *SOLD*
1963 Chevy Nova II 88mm turbo 408 LSX backhalved and tubbed 9.22 @ 145 @ 5000ft BUILT NOT BOUGHT!
02 Cummins ECSB 5 spd,250s,edge comp 64 over a s475.. Work Truck
ifitssmokinitsstrokin is offline
post #9 of 21 (permalink) Old 04-06-2010, 06:23 PM
99whitetanpsd's Avatar
Send a message via AIM to 99whitetanpsd Send a message via Yahoo to 99whitetanpsd
i dont have a 6.0 but i put that fuel spring in my 7.3 and is doin just fine. got a little more pep
E99 f250 4x4 CC SB (sold)
7.3L powerstroke
292hp 658tq
[email protected] 1/8 mile
06 ram 2500 4x4 qc sb
5.9L 24V cummins
Originally Posted by Deereman4020 View Post
Fuk D-maxes I'll get a cummins before a D-max.
99whitetanpsd is offline
post #10 of 21 (permalink) Old 04-06-2010, 08:41 PM
Per Ford's specs, minimum fuel pressure at WOT under load is 45psi. I have heard that anything over 70psi is bad on the injector o-rings in the 6.0
2004 F-250 Lariat X-Cab LB
  • Arp Head Studs w/Black Onyx Gaskets
  • MBRP 4" Turbo Back
  • SCT with tunes from ID and Gearhead
  • Oil and Coolant Bypass Filters
  • Fuel Pressure, HPOP Pressure, Boost and EGT on the A-Pillar
  • Edge Insight Monitors EOT, ECT, Tranny Temp
  • Anti Hi-Jack Device by Glock 9mm!
  • And tons more modded
pro350hydro is offline
