Mild Build Questions/Suggestions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 36 (permalink) Old 04-05-2010, 08:31 PM Thread Starter
WINNING
Countryboy07's Avatar
I am getting ready to tear into my truck for a "mild" build and I am looking for suggestions as to what else to do while I'm in there. I currently have a II 62/70 turbo and I am getting a set of 190cc sticks from Casserly. I also have a new set of heads to put on as one of mine is cracked. I was wondering if there would be any benifit to having a mild port and polish job done while I have them at the machine shop. I was also looking into a Fluidampner as it would be a cakewalk to replace while the cab is up. Any other suggestions would be appreciated, however I do have limited income to spend on this as the wife is limiting me
I already have all the supporting mods, just looking for some more things to do while the cab is in the air. Thank you for your help guys and gals
-French
2002 VW Jetta TDI
Countryboy07 is offline
post #2 of 36 (permalink) Old 04-05-2010, 09:04 PM
<-MONEY PITT!!
ifitssmokinitsstrokin's Avatar
Re: Mild Build Questions/Suggestions
Make sure who ever does the port job knows what they are doing!!!
2010 CCSB Afe Intake and dual exhaust
2006 CCLB F-250 Studs,Squeez,EGR delete,RR to AirDog II and a Airraid Intake & Sct Hot tunes *SOLD*
1963 Chevy Nova II 88mm turbo 408 LSX backhalved and tubbed 9.22 @ 145 @ 5000ft BUILT NOT BOUGHT!
02 Cummins ECSB 5 spd,250s,edge comp 64 over a s475.. Work Truck
ifitssmokinitsstrokin is offline
post #3 of 36 (permalink) Old 04-05-2010, 09:26 PM Thread Starter
WINNING
They have done a couple of good running 6.0's around me. I trust their work. Thanks for looking out though.
-French
2002 VW Jetta TDI
post #4 of 36 (permalink) Old 04-05-2010, 09:43 PM
Lead-Don't follow.
06TWO50Diesel's Avatar
If you're looking to save money, you can start by canning the Fluidampr. Haven't heard any good from it, and all the highest hp 6.0s are running stock balancers. That tells you something there.
Port and polished is nice for air flow, but even when done to it's limits, it'll gain roughly 25rwhp give or take a few. So you have to weigh the cost versus the gains. I had the option, but held off when doing my build.
As stated above me, always good to have a solid shop doing the work who has seen and worked on 6.0s before. Sounds like you have that covered, which is great.
Guessing that since you mentioned supporting mods, that studs are already in place. Make sure they are torqued to 270 pounds to hold strong with the extra fuel and (minimally) added heat you'll be pushing into the motor now.
Other areas- check both pumps, high pressure and low pressure oils. Make sure your electrical wiring on top of the motor is cleaned up and not wearing. Look into your FICM, possibly put on a tuned one while you have the motor down, won't hurt to throw on a mild tuned FICM from Innovative when it goes back on, to back up the 190s you're putting in.
I'm just thinking of simple, yet effective things that won't break the bank. Sounds like you have some good hard parts in place and now you'll have some new goodies to back them up.
Hope this helps some
-06 F250 6.0L-SOLD
“We all die. The goal isn't to live forever, the goal is to create something that will.”
---2011 F250 6.7 CCSB---
IDP Tuning+Torq2 | AFE | Recon | AMP steps | RBP wheels | Nitto
06TWO50Diesel is offline
post #5 of 36 (permalink) Old 04-05-2010, 09:47 PM
PETE ENGR PSD
FICM tune
KEVIN
2006 F-350 Kingranch 79,XXX
TAMU_PSD is offline
post #6 of 36 (permalink) Old 04-05-2010, 10:07 PM Thread Starter
WINNING
Thanks for the advice. Forgot to mention that I already have a moderate tuned FICM on the truck. However I am planning on modding it to put out 58V. Also, what about an oil cooler rebuild while I'm in there?
-French
2002 VW Jetta TDI
post #7 of 36 (permalink) Old 04-05-2010, 10:19 PM
PETE ENGR PSD
Deff an oil cooler rebuild. Would suck to tear it apart twice.
KEVIN
TAMU_PSD is offline
post #8 of 36 (permalink) Old 04-05-2010, 11:10 PM
It wasn't me
offroadinginaz's Avatar
WHy not upgrade the oil cooler while our in there? I'm seriously thinking of this
Newman
A few Fords
Special Thanks to:
offroadinginaz is offline
post #9 of 36 (permalink) Old 04-05-2010, 11:17 PM Thread Starter
WINNING
I would love to get something like that, but the wife is already upset that I bought the injectors and turbo Looks like a really cool kit.
-French
2002 VW Jetta TDI
post #10 of 36 (permalink) Old 04-05-2010, 11:21 PM
PETE ENGR PSD
2 grand its steep
KEVIN
TAMU_PSD is offline
