Banks technicooler Question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-29-2010, 09:44 PM Thread Starter
FordSuperDuty05's Avatar
Hey guys i have a question for you i ought a barley used banks technicooler kit came with all the boots, clamps, high ram intake, and the intercool, and intercooler pipes.
My questions is this to insure that its fully clean i want to clean it myself before i install it this weekend and was wanting to know how to go about that i have never messed with one of these before, so is it something as simple as spraying some degreaser on it and just washing it and letting it dry to insure that its clean as possible.
thanks in advace fellas
2011 F-350 Crew Cab Long Bed FX4 King Ranch
FordSuperDuty05 is offline
post #2 of 7 (permalink) Old 03-29-2010, 10:00 PM
gone6.0's Avatar
Re: Banks technicooler Question
Degreaser wont hurt the outside, try not to get any on the inside block the holes off, unless you suspect dirt inside then it may be impossible to get out, if there is just oil inside just leave it.
04 F250 4x4, 2.5 front level kit, 4" MBRP, Banks Inter cooler, Home made coolant filter, Insight monitor, Nathan K5l horns, ten gal air tank, harpooned, Fumuto valve, custom stripes and decals.
gone6.0 is offline
post #3 of 7 (permalink) Old 03-29-2010, 10:23 PM Thread Starter
well im sure it has some oil on the inside from the CCV but i have mine re routed so that will all stop and i not really concered about the inside i just wanted to clean the out side to insure that all the dirt and grime and whatever is off of there to insure that it breaths as good as it can
post #4 of 7 (permalink) Old 03-29-2010, 10:47 PM
Attention Whore
UNBROKEN's Avatar
Get some AC coil cleaner from a hardware store for home AC units...spray on, rinse off, install IC.
Spending money I don't have on crap I don't need to impress people I don't know.
UNBROKEN is offline
post #5 of 7 (permalink) Old 03-29-2010, 11:05 PM
Arctic Fox's Avatar
Originally Posted by FordSuperDuty05 View Post
well im sure it has some oil on the inside from the CCV but i have mine re routed so that will all stop and i not really concered about the inside i just wanted to clean the outside
I would be concerned about what's on the inside! Some oil from the ccv won't hurt anything but you don't want any dirt in there.
2006 F-450 XLT 4x4 6.0 Auto 4.30L
Kelderman 4-Link Airbags, Lariat Seats, 2011 Mirrors
CTS, SCT, ARP's & oem Gaskets, BPD 6ph FICM
Spearco IC, Ported Intake, Powermax, 4" Exhaust
BPD Oil Cooler, Oil By-Pass Filter
46,000 miles
Arctic Fox is offline
post #6 of 7 (permalink) Old 03-30-2010, 01:57 AM
bluemountianpowerstroke60's Avatar
when my big trucks pop a turbo and fill up the CAC with oil and all the other good stuff, I reverse flush them with degreaser and hot water, first I lay them flat on the floor and put a little 409 or simple green in and then fill it up to the top with hot water, if your are cearful and don't spill water all over you can see if there are any water leaks(if it don't hold water it aint gona hold 40psi) then I stand it on it's side, cold side up and keep flushing hot water through till the water is clear( you can hook your water hose up at your washing machine hook up if you don't have a hot water hook up) then just let it sit up side down with the ports at the lowest point, could also use a blow gun to blow it out. I have the Banks cooler and they are one nice unit, I think they are built beter than the ones that come on the big trucks
bluemountianpowerstroke60 is offline
post #7 of 7 (permalink) Old 03-30-2010, 04:44 AM
Hey Randall, find a local radiator shop, and have them "hot tank" it for you, it will clean it out inside and out, and shouldn't take too long, then just let it air out, or use compressed air to dry it out.
2005 F250 CC SB 4x4
Trusted Performance Stage 2 fuel system; Fabtech 8" lift;
ARP Headstuds; Banks Intercooler and High Ram Elbow; 4" Exhaust; SCT; Isspro Performax guages
keanoknick is offline
