banjo bolts - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 128 (permalink) Old 03-27-2010, 04:22 AM Thread Starter
matts05f250sd's Avatar
banjo bolts
Well been looking for something cheep to do on the truck so I decided to replace the banjo bolts to the heads. With all the stuff inside it's a wonder they flow any fuel at all! I removed all the stuff inside, drilled the hole to like a 19/32 and chamfered the side holes. Installing the passenger side was a breeze. The drivers side was a PITA, had to remove the air filter assembly and several other parts. Reinstalled, no leaks everythings good.
05 ccsb 4x4,4"MBRP turbo back, zoodad, AFE intake, Recon smoked turn signals, Recon interior lighting, Autometer gauges
matts05f250sd is offline
post #2 of 128 (permalink) Old 03-27-2010, 04:58 AM
Re: banjo bolts
i believe doug mentioned drilling the side holes out to 1/4 inch also.
halerazor is offline
post #3 of 128 (permalink) Old 03-27-2010, 05:44 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Re: banjo bolts
Whoa. Center hole 1/4. Sides 1/8.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #4 of 128 (permalink) Old 03-27-2010, 06:58 AM
Re: banjo bolts
Use the Macro function on your camera when you take pictures that close, that way it can actually focus.
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
post #5 of 128 (permalink) Old 03-27-2010, 08:06 AM
ΜΟΛΩΝ ΛΑΒΕ
Stroked95's Avatar
Re: banjo bolts
Whats the benefit of this, other than what it should do? Does it actually help maintain pressure with the factory set up or is this more geared to a better pump?
2005 F-250
Tuning by-Gearhead Automotive & Innovative
Performance Truck Products
Stroked95 is offline
post #6 of 128 (permalink) Old 03-27-2010, 01:56 PM
Still learning
bad moose's Avatar
Re: banjo bolts
Definitly no on 1/4 on the sides. Been there [email protected]#ked that up. Just 1/4 down the center.
03 F250 King Ranch
SCT tuned by Eric @ Innovative, Exhaust, and Air Raid filter
EGR Deleted
Still to slow
bad moose is offline
post #7 of 128 (permalink) Old 03-27-2010, 05:04 PM Thread Starter
Re: banjo bolts
I will try that with the camera. Sorry that was a 9/32 drill bit I used.
post #8 of 128 (permalink) Old 03-27-2010, 07:02 PM
Joe
flexyford's Avatar
Re: banjo bolts
can you get some pics of exactly how to do this mod? i am thinking about doing it. what are the pros and cons of it also?
2009 F-250 CCSB Lariat, 5" Flo Pro, Minni Maxx, S&B, HID's, Visionary Metals Traction Bars.
flexyford is offline
post #9 of 128 (permalink) Old 03-27-2010, 11:36 PM
<-MONEY PITT!!
ifitssmokinitsstrokin's Avatar
Re: banjo bolts
Hell i have some right here I just ditched to go with the bigger lines/fittings If some one wants um LMK ill put um in the mail otherwise they will just sit here and collect dust...
2010 CCSB Afe Intake and dual exhaust
2006 CCLB F-250 Studs,Squeez,EGR delete,RR to AirDog II and a Airraid Intake & Sct Hot tunes *SOLD*
1963 Chevy Nova II 88mm turbo 408 LSX backhalved and tubbed 9.22 @ 145 @ 5000ft BUILT NOT BOUGHT!
02 Cummins ECSB 5 spd,250s,edge comp 64 over a s475.. Work Truck
ifitssmokinitsstrokin is offline
post #10 of 128 (permalink) Old 03-27-2010, 11:43 PM
BRING DA AMBALAMPS
stroke of luck's Avatar
Re: banjo bolts
pm sent
2005 CC FX4...compounds and everything else that goes with em.
stroke of luck is offline
